Help removing doorframe - Fiberglass RV
Old 08-13-2022, 08:34 PM   #1
Trailer: Bigfoot21
Hi, I'm new to the forum. I have a 2001 21' Bigfoot and have discovered leakage and water damage from the awning attachment points. I need to remove the door frame and can't see any flange on the inside, and the outside has a fibreglass moulding around the door with no obvious way to detach it.
Can anyone give me a hint as to the best way to remove this? I'm leery of just ripping it off by force and creating a bigger problem to solve.
Thanks
Mark.
CaribooMark is offline   Reply With Quote
Old 08-15-2022, 08:20 AM   #2
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
the black trim beside the hinges is a screw cover, it should go all the way around the door, pop it out of the track, and you should see the screws. if you damage the cover, it is available from most RV dealers, I just got enough to do 5 trailers because I had to buy a bundle, but it was less than $30.00
joe
Old 08-21-2022, 12:50 PM   #3
Kenny Strong's Avatar
Trailer: 93 "Lil" Bigfoot 13.5'
Utah
As Joe states remove the black stripping inserted in the aluminum frame. new replaced vinyl stripping can be bought from All-RITE.com
Later Kenny
Kenny Strong is offline   Reply With Quote
Old 08-21-2022, 01:29 PM   #4
Utah
It is called 1/2" ridged it comes in cream color not black.
Old 08-25-2022, 11:07 AM   #5
Trailer: Bigfoot 17
Wisconsin
Before you damage something.....I had an issue with leaking door frame. In order to gain access, you must remove 3 screws that are buried in the fabric above the entrance door. The screws are inside the camper and screw into a wood structure. This structure holds the exterior "trim" or rim tight to the camper. I can dig for photos if needed. I did a previous post on this.
Rx2fish is offline   Reply With Quote
Old 02-13-2025, 04:26 PM   #6
CO
Remove Bigfoot trailer door frame
Rx2fish, if you have photos, it would be a big help to me. I need to remove door frame from my 2002 21’.
pianopc is offline   Reply With Quote
vin
What to use to reattach closet to doorframe Jordan O Problem Solving | Owners Helping Owners 0 08-14-2021 02:40 PM
Closet to Doorframe attachment help! Jordan O Problem Solving | Owners Helping Owners 6 08-08-2021 01:00 PM
Bigfoot RB21 Doorframe removal PrimitivePete Problem Solving | Owners Helping Owners 1 09-27-2020 09:25 PM
Need help removing a frig in a '77 Trillium 1300 Ted Problem Solving | Owners Helping Owners 3 09-22-2012 02:50 PM
Help needed removing a firmly stuck brake drum! Kevin A Towing, Hitching, Axles and Running Gear 15 09-17-2009 09:13 PM
