hitch wobble - Fiberglass RV
Old 06-02-2018, 07:17 PM   #1
Trailer: Trillium Sidekick 15
Bay Area California
hitch wobble
Hi, I have a new tow vehicle, a Mazda CX 9. The new hitch I had installed has so much play that my 15ft Trillium is rattling all over my spine. I have purchased u bolt shaped hitch stabilizer, and wonder, does anyone have one installed? I am skeptical as I look at my Amazon purchase.
Patricia
Valentine is offline   Reply With Quote
Old 06-02-2018, 07:39 PM   #2
I like my "Quiet Hitch". It really took the "slop" and noise out.
Old 06-02-2018, 07:50 PM   #3
Bay Area California
thanks
That does look like a good set up. Do you have to remove it to pull out the ball part? My arthritis is slowing everything down... What tools are needed?
Old 06-02-2018, 08:02 PM   #4
I use the same or a similar one. I always install it with the nuts and plate on the bottom thinking that you want to pull the draw bar down rather than up. I'm not sure it makes any difference.
Dave Fish is offline   Reply With Quote
Old 06-02-2018, 08:25 PM   #5
Bay Area California
more thanks
Did you buy it on line?
Old 06-02-2018, 08:33 PM   #6
Got mine on Amazon.
Old 06-02-2018, 08:47 PM   #7
emij's Avatar
Trailer: 2005 Scamp 16
We have the same set up, purchased from Amazon. It really does quiet the hutch and prevent that wobble.
emij is offline   Reply With Quote
Old 06-02-2018, 09:10 PM   #8
Yes, you do need to remove the Quiet Hitch clamp to remove the ball mount because the clamp pinches the ball mount down onto the receiver, but it only takes a 9/16" wrench or 9/16" socket with ratchet. Just takes a minute to put on or take off and weighs very little.
Old 06-02-2018, 09:15 PM   #9
Bay Area California
Thanks everyone...
I'll try it out!
Old 06-02-2018, 09:19 PM   #10
If you look closer, you'll see that I did mounted the Quiet Hitch clamp so that it snugs the ball mount bar down (normal position under load). I just chose to have the threads pointed up to make it easier to see the threads and tighten the nuts while standing. It would be the same force if you rotated the clamp 180 degrees, but then the threads would be under the hitch, pointed down away from you, and you'd have to almost get down on your knees to tighten the nuts. It's not my knees I'm worried about, it's getting back up off my knees once down there that I try to avoid if possible....
Old 06-02-2018, 09:36 PM   #11
Bay Area California
All about making it easy
I'd like to see the bolts as my bifocals add a challenge when getting down.... so now I have to get some options and try them out before my big 2 month trip north from California all the way to Banff and points beyond. This retirement is FANTASTIC.. Thanks to all for the encouragement.
Scamp 19: Old hitch vs. New Reese Hitch Keith2000 Towing, Hitching, Axles and Running Gear 42 03-20-2018 12:39 PM
5th wheel hitch to hitch pull jackstrr Towing, Hitching, Axles and Running Gear 9 07-19-2011 04:19 PM
"U-Hitch" Rear Hitch Receiver Tim Ryce Modifications, Alterations and Updates 9 03-12-2009 04:05 PM
Hitch Aid / Bumper Guard Behind Hitch Ball? Parker Buckley Problem Solving | Owners Helping Owners 12 01-27-2008 04:05 PM
