Hollow door separation - Fiberglass RV
Old 06-01-2020, 04:48 PM   #1
Newtown
I am getting ready to fix the alignment of the door on my 1975 Trillium 1300. There are many threads on the hinges that I will go thru. What I noticed, while studying the problem, was an additional issue of the door coming apart on the seam by the hinges.
What does this group think about spraying foam down inside that crack, wait till it starts expanding out, then use a series of clamps to hold it. The door is hollow to finish expanding in and I will only spray a minimum amount. I think it will hold the two parts of the door together nicely while allowing some flexing. If you think it is not a good idea then how would you deal with it? And how should I clean the inner surface for good bond? I'm thinking it is good enough for the foam. Thanks for your thoughts.
Name:	Trill Door Crack.jpg
KennyCharlie is offline   Reply With Quote
Bigfoot - Question about separation on the roof GeneM Care and Feeding of Molded Fiberglass Trailers 19 10-21-2013 10:20 PM
Help - fiberglass separation issue jalero Problem Solving | Owners Helping Owners 13 09-07-2013 09:37 AM
Bubbly separation of Boler popcorn liner from ceiling Peggy Problem Solving | Owners Helping Owners 1 08-26-2013 08:29 PM
Uhaul inner/outer wall seam separation bard278 Problem Solving | Owners Helping Owners 12 09-22-2011 06:44 AM
Fool Hollow Lake Gina D. Camping, Campout Reports 13 06-25-2009 03:32 PM
