How level is level - Fiberglass RV
Old 08-05-2019, 10:31 AM   #1
Trailer: scamp 13
Wisconsin
How level is level
What are the tolerances for being level for a scamp 13 to be safe for proper operation of fridge? Also could anyone comment on typical maintainance for Dometic fridge. Thanks
Nosirrahrick is offline   Reply With Quote
Old 08-05-2019, 11:03 AM   #2
With newer refrigerators, level is not as critical as some older (20 years) units. If the trailer feels comfortably level to walk around in, you are probably good to go. I always carried a very inexpensive Harbor Freight plastic level that cost less than a dollar. I would first level the trailer side to side using blocks, then front to back using the tongue jack. Lots if time, I would not detach the trailer for several days and there would be some noticeable , but not inconvenient slope to the trailer, and the refrigerator worked well.
Old 08-05-2019, 11:28 AM   #3
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
Another way to look at it: if you can sleep comfortably in it, it's level enough.
Old 08-05-2019, 11:45 AM   #4
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Regarding level, a quick search found this:
"Thank you for contacting Dometic. The refrigerator should not be more than 3 degrees unlevel left to right, or 6 degrees unlevel front to back. We do not recommend having the unit unlevel for more than 1-2 hours as this can increase the chances of a blockage. However, we do recommend if you can, have the unit level at all times."
This was posted in 2017 in the irv2 forum by someone who owns a Dometic RML8555 fridge. They had emailed Dometic and received this response. If you want specific guidance on your fridge, email the manufacturer.
Old 08-05-2019, 01:38 PM   #5
ZachO's Avatar
Trailer: Sasquatch
Montana
6 degrees is a LOT. Even 3 degrees is pretty drastic inside the trailer. So yeah, as long as your fridge is fairly new, you're fine if you're comfortable in it. If I'm parking for more than 15 minutes and I can't find anywhere flat, I turn off the fridge.
There's a lot of info out there on fridge maintenance. The burner assembly is what needs to be cleaned about once a year. Burner jet, burner, and very occasionally the chimney flue.
Old 08-05-2019, 02:10 PM   #6
member
Isle of Wight
I've never been able to sleep comfortably in my fridge....
WizWid is offline   Reply With Quote
Old 08-05-2019, 02:17 PM   #7
Trailer: Roamer TC
Georgia
If you can see the back side of the refrigerator you will see slightly slanted pipes, probably at less than 3 degrees slope. These are the issue. The liquid will get trapped in these if it is not able to run down the spiral pipes continuously. Liquid gets stuck and damage is done in the boiler part from lack of enough liquid.
As long as the pipes have a down slope you are fine.
You can see front-to-back there is more pipe than side-to-side so is the reason they give two different angles which you can be leaning.
I was surprised they said it could be out of level for so long. I always figures 10 mins would start the damage process. Is good to know if it is true.
While you are driving the liquid gets sloshed around so much that level is not a factor.
I think this is the refrigerator, not the trailer, dont get this confused. The two are 90 degrees rotation off each other if fridge is on a side wall. Trailer 3 degrees front to back, 6 side to side.
Roamer is offline   Reply With Quote
Old 08-05-2019, 03:42 PM   #8
ZachO's Avatar
Trailer: Sasquatch
Montana
You must be seriously pampered Mine suits me just fine.
Old 08-05-2019, 08:10 PM   #9
Trailer: Escape 21C
Tennessee
Wink Casita
We keep plenty of 10" long 2x6 wood blocks for the purpose..keep that bubble "betewwen the lines" and no problemo..a bit head up for sleeping, but still w/in the bubbles.
Fred762 is offline   Reply With Quote
Old 08-05-2019, 09:37 PM   #10
floyd's Avatar
What bwand is you fwidge?...A Westinghouse??
Old 08-06-2019, 07:43 AM   #11
ZachO's Avatar
Trailer: Sasquatch
Montana
I joined the circus when I was young and trained as a contortionist...
Old 08-06-2019, 09:57 AM   #12
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
Thanks aj. That seemed wrong to me as well.
Walt
WaltP is offline   Reply With Quote
Old 08-06-2019, 12:33 PM   #13
Maneelu's Avatar
LOL......that was funny widgetwizard. Glad to see people's humor. ��
Maneelu is offline   Reply With Quote
Old 08-14-2019, 10:09 AM   #14
fridge level
We use a simple 9" level to check whatever we can control (mostly front to back slope) in our 2009 13 ft Scamp. Never had a problem with the fridge. Years ago, had fridge in a van that NEVER seemed to work, and I suspect it was far more sensitive re: level than my 2009 Dometic is. (and of course I was much less informed....)
Richard Davis is offline   Reply With Quote
Old 08-14-2019, 10:17 AM   #15
Civilguy's Avatar
Puget Sound, WA
I don't know that there is a lot of maintenance involved. Mostly we see people having issues with maintaining adequately cold temperatures, particularly with side-vented applications.
Here's a link to brief article with a couple of thoughts regarding operation and maintenance.
5 Tips For RV Refrigerator Maintenance
Civilguy is offline   Reply With Quote
Old 08-14-2019, 12:23 PM   #16
Trailer: Vagabond
Nevada
I've always found it too cold to sleep in my refrigerator, my wife has hot flashes so she prefers it.
BushWacker is offline   Reply With Quote
Old 08-25-2019, 11:38 PM   #17
Trailer: 1976 Prowler
Mine works quite well being out a 1/4 inch at 2 feet. Much more than that not so good. Hope that helps.......
Caribooredneck is offline   Reply With Quote
Level Commander II 1985 bigfoot tank level indicator evenweight Electrical | Charging, Systems, Solar and Generators 0 04-14-2017 09:27 PM
How level is level? Cam A Care and Feeding of Molded Fiberglass Trailers 29 05-27-2014 06:58 PM
How level is level? DaveK Problem Solving | Owners Helping Owners 8 06-06-2007 11:03 AM
new level and power gauges Joe MacDonald Modifications, Alterations and Updates 8 12-12-2005 06:37 AM
Water Level Steve L. Modifications, Alterations and Updates 2 11-15-2005 08:48 AM
