How to remove my furnace? - Fiberglass RV
Old 07-10-2020, 04:10 PM   #1
WA
I'm tearing out the inside of my 92 Casita Spirit Standard and can't quite figure out how to get the furnace out.
It's located below the sink
Name:	<a title=Furnace front.jpeg Views: 8 Size: 143.6 KB ID: 135948" style="margin: 2px" /> Click image for larger version
Name:	<a title=Furnace inside.jpg Views: 12 Size: 235.1 KB ID: 135955" style="margin: 2px" />
The diagram shows screws in the bottom of the front edge of the unit and at the exhaust vent
Name:	Furnace diagram.JPG
I opened up the front and there are no screws on the bottom edge, so I went around to the vent on the outside and it isn't attached with screws.
Are these rivets that I need to drill out?
Thanks!
HeavyC is offline   Reply With Quote
Old 07-10-2020, 04:13 PM   #2
WA
Sorry for the messed up picture formatting...not sure what happened.
Old 07-10-2020, 06:49 PM   #3
Trailer: 2014 Escape 21, Lil Joe
Disconnect your four wires and gas line. There is usually a couple of screws near the front holding the furnace in place. Check for other hidden screws. The wall exhaust piece and furnace have two tubes that slide into each other and they should slide apart and that supports the rear of the furnace. Some times the tubes get stuck, wiggle or tap them if you can. The four pop rivets hold the exhaust piece to the trailer. You may be able to wiggle the exhaust port to separate the tubes if you remove the rivets as a last resort.
Eddie
Old 07-10-2020, 07:17 PM   #4
Steve Hammel's Avatar
Trailer: Casita SD 17
Loon Lake Wa. and Boulder City, Nv.
You do not need to drill out the outside rivets. They hold that plate on and the furnace has tubes that insert into it. Why are you removing your furnace?
Previously Owned: Trillium 4500, Scamp 19', Bigfoot 17', Boler 17', Bonair Oxygen, Hymer Touring GT, Scamp 13 Deluxe.
Old 07-10-2020, 08:16 PM   #5
Trailer: 1992 Scamp 13'
This guy has a good video that shows what to do.
1992 Scamp 13' Standard, 2017 Casita 17' ID,
2008 Scamp 16' Deluxe Layout 4
lisantica is online now   Reply With Quote
Old 07-13-2020, 09:39 AM   #6
WA
Eddie
Thanks Eddie,
The two screws in the front (bottom edge) aren't there. I poked around a lot with a flashlight and couldn't find any hidden screws. I'll pull the sink this afternoon and check for other screws from the top. If that doesn't work then I'll try some gentle taps on the tubes. I yanked on the furnace pretty hard though, so if the tubes are stuck together they're really stuck tight.
I'll let you know how it turns out.
Old 07-13-2020, 09:41 AM   #7
WA
Thanks Steve,
Glad to know I don't need to remove the exterior rivets. I was dreading that.
I'm in the process of doing an interior refresh/upgrade and need to pull the kitchenette in order to do the floor.
I'm planning to start a build thread soon.
Old 07-27-2020, 10:07 PM   #8
WA
After a while of poking around I figured out what was going on. Below the furnace exhaust there were two bolts under the snap caps
Name:	Exhaust bolts.jpg
I removed these and found that they were drilled into the side of the block of wood supporting the back of the furnace
Once removed I was able to slide the furnace out a bit.
You can see that the block of wood is coming out as well, which explains why I was having problems. The back of the furnace was connected to the block of wood which was connected to the side of the trailer.
Name:	Furnace back screws.jpg
On to the next issue!
Old 07-28-2020, 10:40 AM   #9
Timber Wolf's Avatar
North Florida
Glad you figured it out. For archive purposes I will post what I did after removing the heater from my Scamp. As I was going back with a Propex in a different location I needed to block off the vent holes in the side of the camper. I drilled out the rivets holding the heater plate to the trailer and removed it cleaning off old caulk. Then I cut a piece of copper that just fit inside/behind the vent cover. Putting a little caulk on the top and sides I re-riveted the cover to the side of the Scamp. Since the copper was already tarnished and brown it looks just like the dark holes in the vent.
furnace
how to remove hydro flame furnace vent cover Tyhee Problem Solving | Owners Helping Owners 6 09-15-2016 07:57 AM
How do I remove furnace from Scamp? Help! Timber Wolf Problem Solving | Owners Helping Owners 8 06-14-2014 07:06 AM
How to remove the furnace in the 1982 Bigfoot camper trailer ? Bigfoot_Canada Problem Solving | Owners Helping Owners 3 05-21-2012 08:41 PM
How to remove Trillium furnace (Duo Therm 65810-002) Isaac M Problem Solving | Owners Helping Owners 1 08-09-2010 01:18 AM
to remove decals or not to remove johnsoba General Chat 15 06-08-2006 12:10 AM
