How to volt meter and switches: drilling into Scamp interior wall. - Fiberglass RV
Go Back   Fiberglass RV > Maintenance | Restoration | Modifications | Problem Solving > Problem Solving | Owners Helping Owners
Click Here to Login
Old 11-07-2021, 03:25 PM   #1
Trailer: scamp 13
I am wanting to mount an on-off switch and also an Anderson power-pole panel in a 2015 Scamp 13. One thing I will need to do is drill holes with diameter of around 1" to 2" into the interior cabinet wall near where the electrical panel and the fridge are.
I was hoping to get advice about the best sort of drill to use, how to approach this and anything else that will make me more of an expert doing something for the first time (if that is possible). Do paddle bits (sold for drilling wood) work well? Will they get dull fast? What are some potential pitfalls and issues I could be aware of? I am hoping to do this in the best possible way and wondering what I need to order and think about. Thanks very much.
zack sc is offline   Reply With Quote
Old 11-07-2021, 03:37 PM   #2
Name: You can't call me Al
Trailer: SOLD: 1977 Scamp 13'
Massachusetts
I wouldn't use a spade bit. It will likely jump around and make a mess. (They do that for me anyway!)
I would use a "hole saw" with a center bit.
You can find them on Amazon or at your local hardware store.
The first one you get should come with a center piece that holds a regular drill bit and the hole-saw part attaches to it.
After that, you just buy the hole-saw part in different sizes and attach them to the first part.
You'll understand once you start looking for them. Make sure the "Arbor" is the right size for both 1" and 2" saws.
A 1" and 2" setup should be around US$25 for both if you're getting non-junk ones.
The nice thing about this design is that the center drill bit is longer than the hole-saw part so it drills through first and keeps the thing from jumping all over the place as you drill the larger hole.
I've had real good luck using these things in thin wood/metal and fiberglass although I haven't used one in my Scamp.
https://www.homedepot.com/p/Milwauke...9662/202327732
https://www.homedepot.com/p/Milwauke...9624/202327750
AlanKilian is offline   Reply With Quote
Old 11-07-2021, 04:33 PM   #3
AC0GV's Avatar
Wisconsin
Know what's behind it.
When I put mine in I removed the drawer for a look and then removed the range top for access, but no two are alike. My USB and power poles are around the corner.
Then when I installed the radio I drilled a small hole in from the cupboard side and then inserted an inspection camera. Yes I bought the camera for this project, it was cheaper than wrecking a new RV. Hole saws for all holes. AND DO NOT PUSH, LET THE SAW DO THE WORK. A second person with a vacuum helps control the dust.
Old 11-07-2021, 04:59 PM   #4
If you ate only going to drill a couple of holes, a less expensive set will do.
https://www.harborfreight.com/34-in-...-pc-57524.html
Make sure you do not drill through something else behind where you drill the hole. Wiring, plumbing, etc
Old 11-07-2021, 05:28 PM   #5
Dan Meyer's Avatar
I installed a few 2 inch gauges in my Scamp, and learned that I needed a hole that was a bit larger than what a 2 inch hole saw made. The solution was to tape a piece of sandpaper around the circumference and drill it thru the hole again. http://scamp.n0kfb.org/mods/gauges/hole-saw-iv.jpg
--Dan Meyer
Old 11-07-2021, 06:54 PM   #6
If you can get to both sides with a drill then a spade bit with two sharp tines on the edges will cut a neat circle with clean edges. When the tip pokes through the back then move and finish from that side.
I also like the Unibits that make nice clean holes, and are stepped.
Old 11-13-2021, 08:03 PM   #7
Trailer: 1971 Boler 1300
Drilling into walls
If you are serious about doing this right then there are some basic rules,
#1, don't buy the cheapest cutting tools you can find, you will regret it.
Buy or borrow good quality hole saws, do not use a spade bit, that is not what they are designed for.
#2, make sure the inside and outside of where you are going to drill are clear of any obstructions.
#3, drill a small pilot hole where the center of the big hole is going to be.
#4, start from the inside with the hole saw until you have a continuous groove then move to the outside and finish the hole, you will get nice clean edges.
#5, give the edge a light sanding to get rid of any slivers and you're done.
Should look amazing.
Best of luck, it's easier than it sounds.
rjanders is offline   Reply With Quote
Adding 12 volt dc switches in a Scamp 13. zack sc Electrical | Charging, Systems, Solar and Generators 13 07-10-2021 05:21 AM
Fastening/drilling into 13' Scamp rear window interior frame? RuthWI Modifications, Alterations and Updates 1 04-19-2019 01:36 PM
Battery disconnect and volt meter Terry M Problem Solving | Owners Helping Owners 2 05-28-2015 05:39 PM
Volt - Amp Meter Darwin Maring Electrical | Charging, Systems, Solar and Generators 2 07-12-2013 11:36 AM
Looking for a Good Volt/Amp Meter curtis c Problem Solving | Owners Helping Owners 4 05-13-2009 08:09 PM
