Humming gas regulator - Fiberglass RV
Old 08-15-2023, 09:11 AM   #1
Trailer: scamp 13
Wisconsin
My concern probably has been discussed many times, but I can't find it doing a search. I have an older Scamp that the gas regulator hums intermittently does this mean that it needs replacing?
Tomas is offline   Reply With Quote
Old 08-15-2023, 07:02 PM   #2
CharlesinGA's Avatar
You could invest in music lessons for it........................
Making noise while gas is flowing thru it is not unusual. Making noise while gas is not being used by any appliance, that is not good. If the regulator is over 10 years or so old, it probably should be replaced. Seals and diaphragms do go bad, even in the best of components.
Charles
'03 Ram 2500 CTD, 5.9HO PacBrake six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. Previously, 2008 Thor Freedom Spirit 180, SOLD! 2007 Winnebago View 23H Motorhome, SOLD!
CharlesinGA is offline   Reply With Quote
Old 08-16-2023, 08:50 AM   #3
It probably just doesn't know the words!
Old 08-17-2023, 05:58 AM   #4
Trailer: ex-Casita, now Alto R series
Massachusetts
common in fluid pressure reducing valves
The 'hum' is a result of the gas pressure regulation process by which the valve is being rapidly opened and closed to make up for the consumed gas, while limiting the pressure available on that appliance side of the valve.
A diaphragm opens a valve to permit the higher pressure on the tank side to flow into the lower pressure appliance side, but just until the appliance side reaches its lower, less-than-tank-pressure limit. That lesser pressure on the low, or appliance, side then closes the supply from the high pressure tank.
As the appliance consumes that gas on the low pressure side, the pressure on that side drops and re-opens the valve to permit more high pressure gas to be supplied.
The pressure on the appliance side rises and the valve closes again.
Turn up the appliance burn rate and the valve needs to stay open for a longer percent of the time. The valve cycles slower and the 'hum' frequency changes.
Turn down the appliance burn rate and the valve stays open for a shorter percent. The 'hum' frequency changes.
Jon MB, (the lesser half of Bonnie RB )
Jon MB is offline   Reply With Quote
Old 08-19-2023, 10:39 AM   #5
Trailer: 1979 Layton 22 ft / 2004 Ram-Cummins 2500 2wd
The phenomenon that results in the 'Hum' is also applied in the operation of 'Air Horns' on heavy trucks, trains, and ships, but amplified by tuned 'trumpets'.
We had a 'humming' regulator (with an extended vent) on our home natural gas supply. When we pinned down the source of the noise reverberating through the entire house, we called the supply company. The service tech removed the vent extension (required because of proximity to basement window) and the 'resonance' changed, eliminating the noise. 'Aha!' he said, and proceeded to replace the regulator and vent extension. Three plus years and no buzz.
Lloyd (aka Santa) Coltman is offline   Reply With Quote
Upgrading to two stage propane gas regulator Courier 3.2 Problem Solving | Owners Helping Owners 6 05-23-2015 05:28 PM
Humming noise on shake down trip Hman66 Electrical | Charging, Systems, Solar and Generators 24 11-02-2013 02:01 AM
Single gas tank regulator - Scamp ShelleyZen Problem Solving | Owners Helping Owners 2 08-13-2013 10:54 PM
What signs that a gas regulator needs changing? TonyB Problem Solving | Owners Helping Owners 1 04-17-2009 06:47 PM
Pinhole in Gas Pressure Regulator? Daisy Problem Solving | Owners Helping Owners 3 10-16-2006 09:01 AM
