Hydro Flame Furnace Question - Fiberglass RV
Old 05-29-2021, 03:15 PM   #1
Trailer: Currently Shopping
Newfoundland
Hey there,
I have Ď79 surfside with the original Hydroflame BRC-10 furnace. Iím wondering if itís possible to run a bbq style propane line, such as in the link below, from a 20lb tank directly into the furnace. Iím hoping I wonít need to use the furnace this summer but in my neck of the woods we can get a few nights in the summer when the temps dip low. I currently donít have any propane lines running to any of the appliances, including the furnace, so it would be a quick solution until I run all the permanent propane lines. Iíve attached a photo showing the connection to the furnace, which is typical for the fridge and cooktop as well. I believe itís 5/8?
https://www.amazon.ca/Relishfire-Propane-Pressure-Regulator-Certified/dp/B07CBS25JT/ref=mp_s_a_1_5?dchild=1&keywords=Propane+Hose&qid= 1622316904&sr=8-5
JasonGill is offline   Reply With Quote
Old 05-30-2021, 07:03 PM   #2
Trailer: 1971 Hunter compact Jr, 1979 Terry 19', 2003 Scamp 16'
I don't know that it is a good idea, but it can be done and work. If you do it make sure the line is long enough to set the tank away from the trailer. Never set a tank in you trailer. They cab vent, lines can have small and large leaks. Before you go to the effort verify that the I working well and has no leak in chamber. Then it up to you.
This is when I would use a Buddy Heater along with a smoke alarm and a co alarm until I could finish the work right.
If you going to do it you might might regulator and a separate hose. It's all available at a good Hardware store.
You could run your permanent line to the heater with a capped tee. Then you'll be ready for the future. Check every connection for leaks. It's easy to get a leak when you're hooking up and disconnecting lines over and over. There will be many who don't agree. Just carefully. You sleep in the trailer.
Terry in Fowler is online now   Reply With Quote
Old 05-31-2021, 06:11 AM   #3
Newfoundland
Thanks Terry, still doing some research on this. Appreciate the help!
furnace
how to remove hydro flame furnace vent cover Tyhee Problem Solving | Owners Helping Owners 6 09-15-2016 07:57 AM
hydro flame furnace only works on 120ac Tyhee Problem Solving | Owners Helping Owners 5 04-17-2016 09:26 PM
Hydro flame furnace eriksob Problem Solving | Owners Helping Owners 7 12-31-2009 04:25 PM
Hydro Flame Furnace Legacy Posts Care and Feeding of Molded Fiberglass Trailers 10 04-06-2003 03:45 PM
