I need to cover my Scamp for Winter - Fiberglass RV
Old 10-23-2021, 10:31 AM   #1
Trailer: 87 13'Scamp Deluxe
Nevada
Does anyone have a good recommendation for a trailer cover? I purchased one through Scamp that had to be repaired each Spring because it tore along the fabric line between the side panels and the white roofing.
Any help would be appreciated.
John T.
Chooch is offline   Reply With Quote
Old 10-23-2021, 10:43 AM   #2
The only better option I know of is Calmark. Be prepared for sticker shock. I've never used one, but I believe they're around $600. Very well made by all accounts.
For many years I "covered" my Scamp for the winter with a good coat of marine wax every fall (and again in the spring). Two coats on the roof, one on the sides.
She now has a snug berth in a garage with a 9' door.
Old 10-23-2021, 01:35 PM   #3
Nevada
Great idea about a covered storage garage��
Old 10-23-2021, 03:28 PM   #4
Saw your title,
and I had to laugh.. because, no you don't.
In fact it is probably true that summer sun does more damage than anything in winter. Frequent waxing and treating rubber items will protect from UV damage. Tires covers are good. A/C covers protect from sun light and bird nesting.
IMHO, the best options for low maintenance are a climate controlled garage, a non-climate controlled garage, a good carport, a Calmark cover, a temporary carport cover (strengthened and with cover removed when weather is bad). Winter won't kill your camper (except for maybe very extreme snowfalls in which case a cover would not make any difference).
Old 10-23-2021, 09:54 PM   #5
AC0GV's Avatar
Wisconsin
I use a round top
If you get snow you will need to remove it.
Old 10-24-2021, 04:19 AM   #6
Trailer: Boler 13 ft
for years now i just use a Large Car cover ... no special brand just need to make sure it will fit and lots of times i find them at discount stores or Goodwills for like $20. They last about 4 or 5 years.
Old 10-24-2021, 09:31 AM   #7
Nevada
Perfect!! Thanks
Old 10-24-2021, 09:32 AM   #8
Nevada
Good ideas and thanks
John T.
Old 10-24-2021, 09:55 AM   #9
LarryB.'s Avatar
Trailer: Casita17'Spirit Deluxe (aka: Tweaker's Casita)
Southwest Ohio
Calmark Cover
When I bought my new-to-me 2007 Casita Spirit Deluxe 3˝ years ago, the original owner included a Calmark cover that has a zippered roll-up for the door.
I use the cover inbetween trips and during winter storage. It has held up **extremely** well.
LarryB. is offline   Reply With Quote
Old 10-24-2021, 10:20 AM   #10
wife is real fussy trying to make hospital corners when tieing it all down on the ends and under the belly. and I know knots so getting it off is no big deal. We did buy Tarp clips to put tie downs where we needed them from Tractor Supply but can be found at any big box store.
Old 10-24-2021, 02:34 PM   #11
Trailer: 2018 Bigfoot 21' 25B21FB (PREV: Casita 17' Spirit Deluxe)
I had used this with bungee cords for the first winter season after purchasing the trailer early last year:
Park Ridge Products TRP1216CAMO Park Ridge 12 x 16 ft Heavy-Duty Reversible Poly 10 mil All Purpose Tarp, 12' x 16', Camo/Green
It had cost $38.52
*note that it was 10 mil heavy-duty
biker is offline   Reply With Quote
Old 10-25-2021, 07:34 PM   #12
Trailer: 1977 Scamp 13
Just got a quote for a 13' Scamp cover from CalMark. I hope you're sitting down.
EIGHT HUNDRED AND FIFTY DOLLARS.....plus S&H.
John LF is offline   Reply With Quote
Old 10-25-2021, 07:46 PM   #13
Yup.. that will buy a lot of wax and rubber protectant. Or if you can put up a carport, a nice downpayment on it.. and it is the prefered way to go.
Old 10-25-2021, 07:57 PM   #14
AC0GV's Avatar
Wisconsin
Round top
https://www.menards.com/main/outdoor...4441924568.htm
Old 10-26-2021, 03:50 AM   #15
think I will stick to my Goodwill find, an X-Large, RainX car cover for $20 for the 3rd year in a row.
Old 10-30-2021, 12:33 PM   #16
Kansas
My Cover made from Sunbrella will give double the life of most covers.
richardabush is offline   Reply With Quote
Old 10-30-2021, 03:03 PM   #17
Vanhamies's Avatar
Low cost option
If you can live with just covering it once at the end of the season and not having to get back in a number of times before you take it out in the spring. My suggestion is get yourself a tarp with grommets all around the edges and some nylon rope. Weave the rope in and out through the grommets. Then you throw the tarp over the top of the trailer and you cinch it up like a garbage bag at the bottom. Not very convenient, but cheap and effective.
Vanhamies is offline   Reply With Quote
Old 10-30-2021, 04:26 PM   #18
The problem with a poly tarp is that you first have to wash the trailer thoroughly to ensure there is no grit on it, then wax it, then tarp it. After a good wax job, you probably will be too tired to do the tarping.
Old 10-30-2021, 10:54 PM   #19
Trailer: scamp
Indiana
Never have covered my scamp and never had a problem. I actually will use it for incidents in the winter.
computerspook is offline   Reply With Quote
Old 10-31-2021, 01:17 PM   #20
jgilliam1955's Avatar
Trailer: Casita Liberty
Virginia
John T.
This one seems good.
Casita 16'-17' Prestige 4 Layer Trailer Cover
I priced CalMark & it was $900. To much.
Been with my sweetheart since 1969
2015 Chevy Colorado & 2019 Casita owner
If I won the award for laziness, I would send somebody to pick it up for me.
jgilliam1955 is offline   Reply With Quote
South Texas Travel Trailer Owner Inquiry – Winter Weather, Winter Roads, and Freezing ridergw2001 Care and Feeding of Molded Fiberglass Trailers 14 02-03-2018 08:32 PM
Scamp Cover for winter sal6342 Care and Feeding of Molded Fiberglass Trailers 5 11-25-2017 08:37 AM
To cover the Air-conditioner or not for winter. Daniel A. Care and Feeding of Molded Fiberglass Trailers 2 09-21-2013 08:48 PM
Winter Cover Donna & Chris Care and Feeding of Molded Fiberglass Trailers 17 10-29-2007 07:36 AM
Winter storage--- Cover the tires? Yves Pelchat Towing, Hitching, Axles and Running Gear 4 10-29-2006 06:15 PM
