Originally Posted by stratos119
I would suggest you replace the jack, I'm not big on automatic stuff like an awning for example but adding the automatic tongue jack to our Escape has been a huge bonus to have when setting up and breaking down. If you don't want to go automatic, they make jacks where the crank is it different position.
The problem is not the crank on the jack. The problem is the post blocks the latch to open the tongue box, and the location of the post is determined by the triangular mounting plate. A side-mount, swing-away jack won't work either because the tongue box blocks the frame rail where you would mount it.
Jack-e-Up makes a fitting that allows the jack to be completely removed, which would allow full access to the tongue box when hitched to the tow vehicle, but not when parked unless you use the jack to unhitch and then transfer the tongue to a jack stand or other support when parked. That would be inconvenient, but it would solve the problem.
