The shiny plastic material is the gelcoat coating over molded
fiberglass. Its the same type of material as that used on the outer shell of the trailer. There is wiring behind the backsplash, so be careful. Many folks use command strips, command hooks, etc, to avoid drilling into the gelcoat.
