Jalousie seal - Fiberglass RV
Old 12-18-2019, 05:45 PM   #1
Jalousie seal
ID:	132565I’m looking for the top window pane seal on my front Jalousie window for my 17’ Boler. I have looked at a bunch of sites and I can’t seem to see the right one. Has anyone ordered and installed this seal on their window? See attachment for picture. Thanks
Daryl05 is offline   Reply With Quote
Old 12-18-2019, 09:12 PM   #2
John in Michigan's Avatar
Daryl, this gasket is the Hehr Series 7900 Window top seal (part number H009-482). I have obtained samples from Pelland Enterprises and All-Rite Custom Manufacturing and tested them in the window frame (seem OK), but haven't yet ordered the required 7 feet needed for the two jalousie windows. One problem is that All-Rite only has it in dark brown.
EDIT: The Pelland product can be order in black, and that would match the new Hehr glazing seals that I've replaced in black. But the Pelland product does not lay flat. I am considering just covering the original (gray) top seal with black plastic striping or tape.
Trillium 4500 Journal
https://www.fiberglassrv.com/forums/f...nal-81345.html
Old 12-19-2019, 07:12 AM   #3
Trailer: Trails West
Have you contacted this company? They do have Hehr Window gaskets and they say they have gaskets for the vintage Boler trailers. My friend's son worked with this company the other year and they actually created new gaskets from scratch for his vintage aluminum trailer as no one was selling replacements for those specialty windows. A good small company that cares about you and your gasket needs.
https://www.vintagetrailergaskets.co...railer-gaskets
Old 12-19-2019, 10:58 AM   #4
Thanks for replying John. I looked at those parts you sent and my seal looks like it may be a touch different. I only say that as I have not pulled it out yet and cant really see the whole thing or the side profile. I warmed up my seal with a heat gun to try and pry it out but it was quite resistant and I didnt want to tear it without the replacement. Have you had success pulling your old one out?
Ya my seal is gray also. I could change it to white and it would match the gray glazing seals ok. Are you suggesting to not buy the Pelland and go for the one from All-Rite as it lays flat better?
Thanks for help!!
Daryl
Old 12-19-2019, 11:00 AM   #5
Thanks for the suggestion. I will contact them to see if they have a seal
Old 12-19-2019, 11:06 AM   #6
get samples ...
Daryl,
Yes I agree, pretty difficult to remove the old seals, but I pulled them out, cleaned everything and re-installed them.
Based on your photos, I would say I have exactly the same windows in my Boler 17 -- and exactly the same seals.
I would recommend you contact each company and have them send you samples. Then you can decide. That's what I did.
John
Old 12-19-2019, 11:10 AM   #7
Daryl,
John
Will get some samples John. Were the seals easier to go in than to get them out? Thanks again
Old 12-19-2019, 11:14 AM   #8
Definitely easier re-inserting the seals vs removing them.
New door seal installed, no seal at top of door. Luxus Panzer Problem Solving | Owners Helping Owners 4 05-11-2018 05:18 AM
Hehr Jalousie window header seal FRANK MOLIS Problem Solving | Owners Helping Owners 18 09-04-2016 10:37 AM
removing t-gasket seal jalousie window? jlbails Problem Solving | Owners Helping Owners 9 05-12-2015 05:25 AM
wanted: window seal/gasket jalousie windows Amy W Classified Archives 5 08-21-2010 06:21 AM
I'm looking for a small jalousie window... Legacy Posts Problem Solving | Owners Helping Owners 3 02-04-2003 08:17 AM
