Light above sink not working - Fiberglass RV
Old 08-09-2023, 09:33 PM   #1
All the rest of the lights are working fine except the one above the sink. I even made sure it was not the bulb and it is not. I could not find a loose wire, battery connections are good. The pumps are working fine. Any ideas? The crazy thing is it was fine this morning.
It is a 2016 13ft scamp with bath1
Thanks,
Pygmy owl is offline   Reply With Quote
Old 08-09-2023, 10:20 PM   #2
AC0GV's Avatar
Wisconsin
There is not much to go wrong
Originally Posted by Pygmy owl View Post
All the rest of the lights are working fine except the one above the sink. I even made sure it was not the bulb and it is not. Thanks,
Get out the volt meter or test light and check for power before the switch.(or just switch it several times and see if it starts working.)
Old 08-10-2023, 05:59 AM   #3
Thank you.
Old 08-19-2023, 10:54 AM   #4
dgt
Trailer: Bigfoot 21'
I had the same problem. Ground fault in the circuit has tripped.
dgt is offline   Reply With Quote
Old 08-19-2023, 11:51 AM   #5
Trailer: Looking for
2015 Scamp 13
I had the same thing happen in our Scamp. The culprit was a salt shaker stored in the above sink cabinet tumbled around and salt went through the wire holes jamming up and corroding the switch. I had to fully replace the light fixture which was tedious because the original was mounted with 8 pop-rivets. I mounted the replacement with bolts and caulked the holes to prevent future failure.
Pocket_jon is offline   Reply With Quote
Old 08-19-2023, 01:04 PM   #6
I found a bunch of pepper in the light. I did not know it was there because I bought the trailer used. So I think the same thing happened here. I am going to order a fixture as soon as Scamp has them in stock. Hopefully, that fixes it.
Thank you, guys.
Old 08-19-2023, 04:33 PM   #7
AC0GV's Avatar
Wisconsin
Time for LED?
I am going to order a fixture as soon as Scamp has them in stock. Hopefully, that fixes it. Thank you, guys.
If you search Amazon for "rv dome light" you may save some money on shipping. It is expensive to ship from Backus.
Old 08-19-2023, 08:06 PM   #8
Thanks!
light
1974 Eco sink (faucet not working) BrowningSchubarth Plumbing | Systems and Fixtures 12 07-19-2017 08:13 AM
After-market light bar, visible brake light above rear window EllPea in CA Towing, Hitching, Axles and Running Gear 11 08-17-2015 12:49 PM
HELP , want to mount TV in Trillium above sink Darren Pettis Problem Solving | Owners Helping Owners 26 05-11-2013 12:09 PM
U-haul cupboard above sink Rob Marks Classified Archives 3 10-02-2011 01:39 AM
Wanted: Above Dinette Storage Shelf with light for Trillium 1300 Rodre Classified Archives 2 04-15-2011 10:25 AM
