Marker lens cracks - Fiberglass RV
Old 03-28-2012, 10:00 AM   #1
Raz
Raz's Avatar
Marker lens cracks
Our Trillium came with Bargman marker lights. I am continually finding the lenses cracked. We had the same experience with our previous trailer. I suspect that the reason is moisture freezing and expanding over winter but it might just be vibration. Do folks who live in the sun belt, whose trailers never see freezing temperatures, have this problem? Do others have the problem? Any suggestions on a cure? Raz
Old 03-28-2012, 10:35 AM   #2
Trailer: Bigfoot
Saskatchewan
It could be any reason. Vibration, UV damage, heat from the bulbs (is a problem with the front markers on the 02 Trans Ams). You could look at replacing them with LED fixtures and that may solve the issue.
Orcus79 is offline   Reply With Quote
Old 03-28-2012, 05:27 PM   #3
Trailer: 2008 Oliver Legacy Elite
We have LED taillights, and live in the south, but travel far north. No issues to report.
Sherry
SherryNPaul is offline   Reply With Quote
Old 03-30-2012, 05:44 AM   #4
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
I replaced ally lenses the year I brought the 5500 home, and have not had an issue since, but maybe mine don't seal well enough to trap water inside. I do live in a hard winter area
Old 03-30-2012, 07:29 AM   #5
Just a suggestion, but there's always a gasket used to seal lenses to housings. Why not make your own gasket material out of butyl putty tape? Works for windows, should seal exteriors lights as well.
Old 03-30-2012, 02:45 PM   #6
Greg H's Avatar
Trailer: 72 Boler American
Indiana
Just replace the lights with LED's, they are brighter and use less power and they last longer too.
Old 03-30-2012, 04:10 PM   #7
Raz
Raz's Avatar
Lots of good input, but, just to be clear. I am not concerned with the lights. I am just trying to trouble shoot why the lens covers are cracking. You see if the little bit of moisture that gets in behind the lens is causing cracks due to our local climate, then other parts of the trailer could be affected as well. I was just curious if others were experiencing the same issue. If folks not in the frozen north are having trouble then vibration, not freezing, is the culprit. My apology for not being clearer. Raz
Old 03-30-2012, 10:55 PM   #8
Trailer: Bigfoot
Saskatchewan
The cracking is in my guess, caused by heat build up and vibration.
Boler 1700 Side Marker Lights timmckee Modifications, Alterations and Updates 6 08-15-2011 01:57 PM
wanted Scamp Lens tail light lens cover Flygal Classified Archives 27 05-02-2011 03:11 PM
LF : Boler 1300 marker light lenses skryabin Classified Archives 3 12-01-2010 10:59 PM
Using side marker lights as turn signals al gilliland Care and Feeding of Molded Fiberglass Trailers 30 08-14-2009 04:53 PM
Side marker lights Maggie O. Problem Solving | Owners Helping Owners 10 06-12-2006 03:18 PM
» Trailer Showcase
Bigfoot
sddamours
TBD
LiseKen
