Originally Posted by angitude
Hello
I’m trying to find a supplier of Aluminum or any other light material to trim the table. It had a channel down the middle. No one seems to carry any pliable metal banding. Any ideas?
Thanks in advance
Search for T-Molding. The stuff that I used came from a company in Edmonton called Retro Arcade, or something like that. I think it was similar to this:
https://www.amazon.ca/Edge-Supply-Pl.../dp/B088B8CKFN
I also purchased a router bit to cut the groove, but if you alread have the groove, then you probably don't need it. However, if yours came loose, you may need to use a glue to keep it on.
