Purchased our 1979
Trillium 4500 Gaucho one month ago and well into
renovation.
Windows out and damaged plywood frames removed. Floor plywood intact except for curbside rear corner, which has been excised.
Fiberglass floor running along kitchenette has been cut and then screwed down. Plywood underneath seems solid to probing and appears intact. I plan to grind down fiberglass along the cut, then lay in new fiberglass woven to patch.
I'm curious why this cut was done and if I might be missing something. Of note, I have pulled out the
fridge, which is probably larger than the original since the opening has been enlarged and it is still a tight fit.
Any thoughts about why this cut was made?
