Name for light? - Fiberglass RV
Old 07-03-2017, 03:37 PM   #1
Sue and Henry's Avatar
Name: Sue and Greg
Trailer: 1982 Burro 13 foot and a 2015 Casita Spitit Deluxe 17 ft.
Name for light?
This bulb is about 1 1/2 inches long and came out of the exterior rear light that helps you see the jack on the casita. There are no markings on it at all. I've never seen anything like it (it may be an extraterrestrial bulb from Mars). Does anyone know what it is called and where I can get another?
Sue and Henry is offline   Reply With Quote
Old 07-03-2017, 03:50 PM   #2
Bruce Thomas's Avatar
Trailer: U-Haul CT13
Looks like a lighthouse...ha
Bruce Thomas is offline   Reply With Quote
Old 07-03-2017, 03:57 PM   #3
Name: Sue and Greg
Yes it does [emoji4]
Old 07-03-2017, 04:02 PM   #4
DayTripper's Avatar
Trailer: 12 ft Chariot (Stealth Egg) and 1987 Casita Liberty Deluxe
It's an automotive LED bulb
No idea what your bulb number is, but here is a similar bulb
2 x 18-SMD 5050 18 LED Yellow Tail Turn Signal Lights Bulb 1156 BA15S T20 DC 12V | eBay
DayTripper is offline   Reply With Quote
Old 07-03-2017, 04:03 PM   #5
Glenn Baglo's Avatar
I'd clean contacts before replacing the bulb. LED bulbs last a long, long time.
Old 07-03-2017, 04:13 PM   #6
It is an "aftermarket" LED light made to fit into a standard bayonet base socket. Often used as a replacement for the old filament bulbs.
Old 07-03-2017, 04:13 PM   #7
NW Wisconsin
It looks like the LED lamps I have in my Casita
It's a rather common lamp .
Check LED trailer lights out of Washington State
Cost about $13
I've had them in both my Scamp and Casita , never had one failure.
Old 07-03-2017, 05:13 PM   #8
SteveV's Avatar
Trailer: Amerigo FG-16
That's the same style of LED bulb I put in my Amerigo, bought 10 of them for right @ $10.00 off of ebay. They are a replacement for the 1156 automotive and are polarity sensitive, if it has never worked for you try switching the + and - wires to the lamp.
I would test it with a couple of test leads & a battery first.
SteveV is offline   Reply With Quote
Old 07-03-2017, 06:53 PM   #9
Name: Sue and Greg
You guys are all awesome. Thank you for making the electricity in my life so easy! Sue
Old 07-04-2017, 11:09 AM   #10
Trailer: Casita SD 17'
South Carolina
If this LED came from the fixture over the propane tanks on the front of a Casita, it is probably still good. With the cover off the fixture, spray a little WD-40 on the switch and operate it a few times. That switch apparently gets water in it and doesn't swap sometimes. You can also pull a bulb or LED out of another light in the camper and see if it works there.
Ben
Ben Barkley is offline   Reply With Quote
Old 07-04-2017, 02:05 PM   #11
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
Oklahoma
I have 2 or 3 of those sitting in my drawer.
LEDs often only work one way in the socket. If yours has 2 contacts on the bottom, you may have to flip it over and reinsert it.
Old 07-04-2017, 02:13 PM   #12
I find this stuff solves most of my electrical issues.
Leaves no residue, unlike WD40, and it doesn't stink.
light
Replacing Fluorescent Light with Double Dome Light in Scamp mnimz Electrical | Charging, Systems, Solar and Generators 3 03-10-2017 05:03 PM
After-market light bar, visible brake light above rear window EllPea in CA Towing, Hitching, Axles and Running Gear 11 08-17-2015 12:49 PM
Installed Smart Light 1000 Motion Activated LED porch light Fran L Modifications, Alterations and Updates 2 02-01-2012 03:05 PM
Pilot light won't light (Casita) SW6P Legacy Posts Problem Solving | Owners Helping Owners 5 08-06-2003 09:12 PM
