Need Help finding three moldings - Fiberglass RV
Old 06-13-2021, 11:05 AM   #1
Borden's Avatar
Name: Borden and Carole
Molding for center section of front window, and lever part need a pin other side pin is removable and is sheared in half on this side
Top is top left, middle is the very small top right picture and the bottom left is bottom molding the leaver Model Number: H010-210 Hehr (Deco) Torque Bracket only need a pin as bracket ok. Also need Hehr 4900 Series Screen Clip
Our postage stamp in heaven.
Old 06-13-2021, 11:49 AM   #2
Borden's Avatar
Front window by Hehr
This is the window working on getting moldings for can get deco bracket but it does not come with missing pin. schematic diagram would help a lot.
Old 06-14-2021, 06:01 AM   #3
Joe MacDonald's Avatar
try https://vintagetrailersupply.com/win...are-and-seals/
Joe
Old 06-17-2021, 04:51 AM   #4
TN
I'm looking for the same rubber molding. If I ever come across something I let you know.
Eric Frye is offline   Reply With Quote
Old 06-27-2021, 06:04 AM   #5
Borden's Avatar
Seals
Have ordered close looking top seal, what should be an exact middle and sides seal. Did not find a bottom seal replacement may modify a different seal to make things work, will post how they fit when the order gets to me.
P.S. made a new pin for driver side out of a small bolt that was not full thread works great.
Old 07-07-2021, 09:11 PM   #6
Borden's Avatar
Seals
Top seal replacement works, center and side seal replacement is perfect but bottom did not work, new seal blocks window drains; have a small peice of new seal meant for bottom used on one side. Only two more windows to remove and re-putty.
Want to 3D print the 17" wide, 1" deep vent cap replacement embellishments, they do not make any that wide today, learning software. Caps are 14"
Old embellishments were metal, damaged and do not fit new cap vents.
Will post pictures of parts, and seals used later.
Old 07-08-2021, 03:54 PM   #7
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Borden, congratulations on finding 3 types of seals that worked. Please post the source and part numbers for these three seals when you get a chance. Thank you.
John in Michigan is online now   Reply With Quote
Old 07-08-2021, 06:15 PM   #8
Borden's Avatar
Window Seals
-Different but worked
Model Number: H009-482 worked in top ok even though different no leaks
-These are ok
Model Number: H009-289 fit middle and sides of front window center section
Model Number: H009-344 Black H009-344-19 sliders and fixed sides of front
-Not ok but used a bit on each end temp shrinkage space filler
Model Number: H009-289 block drains and fit was poor
Still need a good bottom seal replacement
https://www.pellandent.com/
Pelland Enterprises
P.O. Box 210
2784 Shirewood Lane
Arnold, CA 95223
1-800-216-2786
1999 Casita - window moldings GerthT Problem Solving | Owners Helping Owners 1 05-25-2017 09:52 AM
where to find interior moldings Claude et Manon Problem Solving | Owners Helping Owners 4 04-11-2017 09:40 AM
Burro Window Moldings and Beads samuelm Problem Solving | Owners Helping Owners 4 05-21-2016 07:50 PM
Hatch Door Moldings Roy in TO Problem Solving | Owners Helping Owners 1 08-31-2008 12:54 PM
Three way LP three burner/grill bonnie w Modifications, Alterations and Updates 2 07-02-2007 04:45 PM
