Originally Posted by Kenny Strong
There is a cap on the side of the mounting hole it looks pear shaped. twisting it counter clockwise should open its locking clip , then pull it away from the mounting point. I bought a pair of tokico Y2505 gas struts. Always buy new even if one of them works. Nothing comes up on Amazon they sell a Y2507. Is it a replacement ??? Measure center of one end mounting hole to the other end center of mounting hole. to compare with the picture shown. Another brand name will work if the length is equal rated at about 25 pounds lift should work I don't know what the Y2505 is rated at but it just lifts the cover.
TOKICO USA inc. 1330 storm parkway Torrancz (Torrance ? )CA 90501
Later Kenny
Kenny, Thank you for the response, and for the information. A friend of mine was able to get the rock guard down for the winter. I don’t think he used the technique you describe above! I am very sure that both struts need to be replaced. I think these are not original ones because I see another hole on each side of the rock guard where previous struts had been attached.
Come next Spring, I have quite a bit of updating to do. A little
Bigfoot needs a new
battery, probably new
propane tanks, a new backsplash, and the window sliders cleaned out and made smooth again. Probably many more things. The poor sweetie has been neglected for the last three years while we dealt with some sad family issues, but I’m anxious to get out in her again.
