new 2018 toilet doesn't work - Fiberglass RV
Old 05-26-2019, 11:43 AM   #1
Toddv78's Avatar
Trailer: 2018 ParkLiner /2015 casita spirit deluxe
My domestic 310 won't flush? I have water coming to shower and it looks like water feeds to toilet from the shower feed but when i push flush lever nothing happens. I took water feed too toilet apart and water is getting to toilet??? need help thanks
Toddv78 is offline   Reply With Quote
Old 05-27-2019, 09:59 AM   #2
Trailer: 2014 Parkliner
Toilet not working
The campers electric flush toilet has a dedicated 15 amp fuse. Mine is the blue fuse #1 in the panel box. The first diagnosis should be to pull the fuse and make sure it isnít blown.
GeorgeH is offline   Reply With Quote
Old 05-27-2019, 10:00 AM   #3
Toilet
Keep spare fuses on your camper
Old 05-27-2019, 10:21 AM   #4
Is there a water-shut off valve to the toilet?
Old 05-27-2019, 12:00 PM   #5
Dan Meyer's Avatar
What happens when you lift the flush lever instead of pushing it down?
--Dan Meyer
Old 05-28-2019, 11:23 AM   #6
Toddv78's Avatar
so the toilet is not electric. the pedal can not be pulled up. there is not a separate shut off just for toilet either. Its a domestic 310 tried flushing both with being connected and with pump and fresh water and nothing
Old 05-28-2019, 12:24 PM   #7
If you are Googling, it's Dometic, not domestic.
Old 05-28-2019, 01:53 PM   #8
Al and Cindy K's Avatar
Since your's is new, this probably isn't the problem but I'll throw it out anyway. When we first purchased our pre-owned Scamp 19 several years ago, the toilet would flow very little water into the bowl. A closer review showed almost all the holes under the rim were clogged with a hard white calcium-like substance. I used an ice pick and clothes hanger to ream these out and its worked fine since. When was the last time your's worked properly?
Al and Cindy K is offline   Reply With Quote
Old 06-01-2019, 03:10 PM   #9
Trailer: Interested
Montana
Dig a Hole
I would say your toilet is in the crapper.Could be a backup issue! To much crap! or you could have just got a crappy deal.
Montana Brad is offline   Reply With Quote
Old 06-02-2019, 09:14 AM   #10
Toddv78's Avatar
Fixed. New valve as tip was broken then the vacuum breaker blew out and replaced it. Never been used. Amazing
parkliner
Plug with camper doesn't work properly help needed please Mcmarkrazz Towing, Hitching, Axles and Running Gear 12 08-18-2013 02:08 PM
Fridge Doesn't work on AC donalie Problem Solving | Owners Helping Owners 3 06-03-2008 08:38 PM
