New Insulation or Keep what is there?? - Fiberglass RV
Old 11-08-2020, 08:46 AM   #1
Wisconsin
Hello All!
This is my 1986 16ft Scamp project. I have some time coming up and would like to tackle this but would like some advice.
Should I keep the rigid foam insulation that the previous owner installed along with the wooden furring strips that the insulation is placed in between or rip it out and install reflectix or something like that instead? I am ordering new windows and need to get the insulation/wall covering figured out in order to install the windows and get this project moving. Would love your thoughts!
Thanks,
Griff
GriffPete is offline   Reply With Quote
Old 11-08-2020, 11:31 AM   #2
Trailer: Waiting
Call Scamp & ask what they recommend.
bact2387 is offline   Reply With Quote
Old 11-09-2020, 12:54 AM   #3
tractors1's Avatar
Trailer: Escape 21 - Felicity
I would not rip out any insulation - just add more. Relectix works best with an air gap, so you might consider more furring strips.
Charlie Y
Old 11-09-2020, 06:44 AM   #4
If you’ll be keeping the original transverse bed layout, adding any additional thickness will shorten the already shortened bed.
Foam is a much better thermal insulator than Reflectix (which is meant to be left exposed as a radiant barrier). If the furring and foam are solid, smooth, and gap-free, I’d be inclined to leave it and put a finish layer of marine headliner (like Scamp’s rat fur) directly over it. But any bumps or gaps will show through the thin headliner.
Leaving all that wood inside the wall could mean trouble down the road if you have leaks in any of the windows or vents. A full resealing of everything now and ongoing maintenance will prevent that. What you have is similar to what Bigfoot does, so you’re in good company!
Old 11-09-2020, 07:21 AM   #5
Wisconsin
Well that definitely makes sense in regard to the wood/moisture. I will be sure to seal it well. I appreciate the advice and will update with more questions as I go along I'm sure! Take care!
Escape Insulation Package vs Bigfoot 4-Seasons Insulation Jane P. General Chat 43 04-18-2019 12:02 AM
New Scamp 13 - Help me keep it simple! morz4 Modifications, Alterations and Updates 20 06-05-2012 08:48 AM
Is There a 2 Sided 110 Plug In Out There? barryra Problem Solving | Owners Helping Owners 9 05-09-2011 02:14 PM
Uhaul CT how many are there out there Lynne VDK General Chat 11 11-20-2010 06:19 PM
Are there any other car crazy people out there? Phil 4500 General Chat 21 08-05-2008 01:46 PM
» Trailer Showcase
LUNA
keekers
Penelope
Penelope
