Hello Everyone I have a couple quick questions about installing a new
propane system for a two burner
propane cooktop and catalytic heater.
Here's a quick backstory so you have the complete picture: We recently purchased a renovated 1976 13'
Scamp. The previous owner did a pretty nice job with a lot of his restoration work, but his intended use is obviously different than mine. He removed all the 12v and
propane systems completely. I think he was intending to use it plugged in exclusively. We intend to do the exact opposite. So our first step in making that possible is reinstalling a propane system.
I already have the propane tank mounted on the tongue. I have purchased a Dometic two burner cooktop (which I've already physically installed) and a Camco Olympian 3 catalytic
furnace. Here's where my question begins...
The
furnace requires a low pressure regulator (11" w.c.) which I have already purchased and tested with the
furnace and a short bit of hose and it works fine. The cooktop manual doesn't mention a pressure regulator ANYWHERE in the manual and it looks to me like there's already a regulator on the unit right where the propane line comes in.
Just for grins I tested the cooktop hooked up to the propane tank through the same regulator that I bought for the furnace. It seems to work just fine that way, even if it does have its own built-in regulator.
So my question is this... where is the best place to split the propane line? Meaning, can I hook the low pressure regulator directly up to the tank and then split the line afterwards and run to each appliance, or should each separate line have its OWN regulator? Or does the cooktop even need one at all (presuming that it does have one built-in)? Or would it hurt to run it behind another regulator?
I'm pretty good with
electrical, but this is my first foray into installing (instead of simply using) propane.
Any helpful ideas? From what I've read here so far, there are ALWAYS helpful ideas.
Thanks in advance!
Troy
