02-10-2019, 07:29 AM
Trailer: 2015 Lil Snoozy
Delaware
New Trailer starter kit
I've ordered my new Lil Snoozy and am waiting, waiting and waiting! While I wait, I've been shopping, shopping, shopping. I've been searching this site trying to find a posting with a recommendation for a starter kit that lists all the items I will need when I pick up. Any suggestions?
02-10-2019, 07:53 AM
Trailer: 2017 Lil Snoozy
South Carolina
Diane, We didn't have a list to go by, but what we did was make a list of what we thought we would need in the camper. When we picked up our Snoozy we did a 'shake down stay' at a nearby campground to figure out what we really did need and didn't need.
One of the first things I did buy was a rug for just inside the door (sink area). Then small pillows for the couch, paper towel holder, TP holder. blackout curtains for the bed area, cutting board to cover the sink area, outside rugs, and a short extension powercord for the outside connection as we have camped at a campground where it wouldn't reach the shore power box by 2 ft! https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Those are just a few things that I can think of now. Have fun shopping!
02-10-2019, 08:17 AM
Delaware
Jan...you are the best. I remember your power cord issue from FB post! Brings me to the question, what length should I buy?
My list is quite long. Most is decorative and doesn't fit needs but the NEED stuff is what I'd like to pre-purchase. Do you have a water pressure thingy (don't even know what it's called)?
02-10-2019, 08:29 AM
member
Isle of Wight
Toilet paper, camera, smile.
Everything else you can pick up on the way.....
02-10-2019, 08:40 AM
You could get away with a regular (15 Amp) extension cord and a simple adapter (female 30A to male 15A). That adapter is also handy without the extension when only 15 Amp shore power is available. That is, of course, unless you think you would run your AC, Microwave, toaster, electric space heater, or whatever, all at the same time.
02-10-2019, 08:49 AM
Delaware
Ha, ha...perhaps a few more things. I travel with 2 big dogs and need those supplies. I guess the princess thing needs to be taken down a notch!
02-10-2019, 08:50 AM
You may consider a water pressure regulator, get one that has the gauge on it. Also one of the blue water filters and maybe a 90 degree hose adapter, depending on where the hose connector is. Get a blow out adapter if you will be where the trailer has to be winterized. Surge protector for the power connection. Ours plugs on to the campground power post and at least indicates the correct polarity. Not sure about how much surge protection. Wheel chocks and leveling blocks. Coupler lock for when the trailer is parked and a padlock for the coupler when towing.
02-10-2019, 08:52 AM
... Do you have a water pressure thingy (don't even know what it's called)?
Those lists can get pretty long, and most of the stuff can be picked up on the way at a Wallmart or such, as the wizard pointed out. The water pressure "thingy" is a pressure reducer. Either a plastic one (~ $5-6), or metal (~ $8 - 12). Either one should last a long time.
And, on the subject of water, I have a garden hose Y-splitter. That way I have a handy water spigot outside.
Delaware
AC always when the weather is warm/hot. Probably best to go overboard now rather than be caught without later. Thanks. This is the information I must have.
02-10-2019, 08:54 AM
Delaware
YES! That's what the thingy is called...water pressure regulator! Great list...thanks.
02-10-2019, 08:56 AM
Delaware
It's all about those thingys. I'm writing these things down now.
02-10-2019, 09:15 AM
Leveling blocks or device (lego blocks/Anderson/BAL).
Small bubble level (or phone app).
Extension cord & adaptors.
Fresh water hose, filter, & regulator.
Simple tool kit.
Spare fuses (assorted sizes).
12V air compressor.
Tire pressure gauge.
Gloves.
Ball grease (white lithium).
Locks for coupler and ball mount.
Anti-rattle device for ball mount.
Credit card.
Sense of humor.
02-10-2019, 09:27 AM
South Carolina
Diane, the one we bought is 15 ft. That's plenty to cover a shortage. We've only encountered it once and we were about 2' short. It was a lifesaver! LOL
02-10-2019, 09:28 AM
Delaware
Simple tool kit.
12V air compressor.
Gloves.
Credit card.
Sense of humor.
Love the last two! Thank you.
02-10-2019, 11:17 AM
Name: To Infinity & Beyond!
Trailer: 1985 Uhaul VT-16 Vacationer, 1957 Avion R20 & 1977 Argosy 6.0 Minuet
Make your Huge List of EVERYTHING YOU THINK you might need to go camping and eliminate 90+% of all that CRAP you thought you might NEED and you might just be be close to your REAL NEEDS when camping.
Don't believe me?
Just look around your current home for inspiration and look at all the CRAP you thought you needed that you NOW never use and NEVER used when you thought you needed it!
The same situation applies even more so when you go camping!!!
Enjoy the Adventure we call camping!
Mike
Remember "Drive Fast, Turn Heads, Break Hearts"!
02-10-2019, 11:33 AM
I carry one of those flat garden knee pads for when I have to get down to set my stabilizers. And one little item that will be for the most controversial piece of equipment, the TV, if you will use one. I have the push on type of connector on the end of my coax cable that connects to the campground plug. I've found the campground connections are usually well worn so that the coax won't screw on and stay on. One KOA that we have stayed at had the push on adapters right on the check in counter for sale.
02-10-2019, 01:35 PM
Trailer: Currently Shopping
I started a list a few months ago when we started looking and I've given it a few updates as I've come across suggestions. This thread has some good new suggestions already.
I think your comfort and convenience needs will vary based on your travel intentions; I've left our "quality of life" items off for that reason. We plan to have everything we want to camp with stowed permanently in the trailer; that way there's no loading/unloading or forgetting. Blankets, pillows, cookware, hygiene items...My hope is that we can just stuff some clothes in a bag and swing by the grocery store on our way out of town.
I divided my list into categories. Things marked (TV) I plan to purchase or already have and will store on a permanent basis in the tow vehicle.
Roadside Repair Kit - Bottle jack (TV)
- Reflective emergency triangles (TV)
- Reflective vest (TV)
- Tire iron (if different that TV's)
Maintenance Kit - Tire pressure gauge (TV)
- Portable air compressor (TV)
- Toolbox (not sure of trailer-specific tools yet)
Safety Items - First aid kit (TV)
- Fire extinguisher
- Wheel chocks
- Weight distribution plates for leveling jacks
- 3-M reflective tape for bumper
Security Items (we can't store on our property, so it will be in a storage lot) - Hitch lock
- Solar lights
- Wheel boot
ISO:
Scamp 16 Deluxe Layout A or C
02-10-2019, 04:10 PM
Trailer: Escape 21' 2nd Gen, picked up on Black Friday 2016
I have a couple of those in the truck for when I have to crawl farther forward in the back area. Even though it has a carpet down (and I have a couple of retriever poles), it still kills the knees.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
This is what I use for hooking up/dumping sewer and the hitch. Bending over isn't the greatest for me.
02-10-2019, 04:15 PM
Delaware
Originally Posted by NW Cat Owner
Very good suggestions. Thanks goodness, no sewer hoses (cassette). Thanks
