Newbie adding a house battery - Fiberglass RV
Old 01-19-2022, 03:27 PM   #1
Hey all,
I have a 78' Trillium 4500 with the factory power converter and I want to add a battery to the system. I am not sure if it has ever had a battery in the trailer or not...there is currently no hook up for one.
I know the factory converter has an option to run 120 or on battery. The load on it will be very minimal. Basically only lights at night (LED) and the odd USB charging task. The trailer has the factory gravity furnace, 3 way fridge and stove top so I assume there will be little to no power draw from the appliances since they will be on propane most of the time.
Is it as easy as wiring in a battery off of the tow vehicle like in the 1300 wiring diagram? Will it charge if I am plugged in to shore power or only from the T.V?
Any insights would be helpful. I have spent the last few days searching the forums and I can't find a straight answer. I would like to keep things as original as possible in the trailer (keeping the factory converter).
Svenny is offline   Reply With Quote
Old 01-20-2022, 10:38 AM   #2
Trailer: 1994 Casita 16 Liberty
Battery
DanielAG is offline   Reply With Quote
Old 01-20-2022, 11:03 AM   #3
John in Michigan's Avatar
Trailer: 1979 Boler 1700
Svenny,
(1) The Trillium 4500 original converter has a simple ac to dc transformer in it, so it is not designed to charge the battery. You can charge the battery with a battery charger when shore power is available, and/or with a solar panel, and/or with a tow vehicle charging wire.
(2) The Trillium wiring diagram is similar to the old Boler and Scamp wiring diagrams and same wire colors. See the basic wiring diagram in post number 11 in this thread:
https://www.fiberglassrv.com/forums/...ent-83543.html
Old 01-20-2022, 11:07 AM   #4
fyi, in my Trillium 4500, I installed an agm battery under the rear driver's side bench. I replaced the original converter with a Progressive Dynamics PD 5000 distribution panel and a built in smart charger. Could have installed a deck mount converter-charger instead of a smart charger.
battery
Casita Battery Charger mods for adding a AGM battery? doctoruv Electrical | Charging, Systems, Solar and Generators 2 02-14-2019 01:51 PM
Battery Charger on Truck or House Battery? dartz Electrical | Charging, Systems, Solar and Generators 13 06-24-2014 07:59 AM
Battery Charging: what limits the amperage to the house bank? Evergreen Modifications, Alterations and Updates 3 01-19-2011 11:47 AM
Alternator charging house battery safely Ami P Problem Solving | Owners Helping Owners 7 12-14-2008 12:59 PM
Kipor Generator for recharging House Battery kevin61 Problem Solving | Owners Helping Owners 8 06-05-2008 05:04 AM
