Noises waterpump - Fiberglass RV
Old 09-24-2020, 07:13 AM   #1
Ohio
Noises waterpump
Does anyone have any good ideas that have worked in quieting a noisy water pump in a Scamp? Our 2015 Scamp water pumped is SO loud. It is embarrassing.
TimandLaurie is offline   Reply With Quote
Old 09-24-2020, 07:44 AM   #2
Quietest one I have found.
https://www.amazon.com/Jabsco-36600-.../dp/B0141OKHC6
I use on for the shower drain because I think it is less likely to plug up, but it is probably OK either way since I installed the filter as well.
Old 09-24-2020, 08:27 AM   #3
John in Santa Cruz's Avatar
Mid Left Coast
thats a bilge pump. is that suitable for use as an on-demand water pump ? typically RV water pump delivers about 35 PSI
Old 09-24-2020, 08:31 AM   #4
Trailer: Escape
Lawrence
Our Casita water system was very noisy too. I found that on my unit, the pump itself was quiet, but that the pex lines needed foam padding to isolate vibrations caused by the pump. Wrapping as many lines as I could get to helped quite a bit. You might try wrapping your water lines first before you go to the trouble of replacing the pump - which may - may not - be the actual problem.
thunderworks is offline   Reply With Quote
Old 09-24-2020, 08:40 AM   #5
Here is a link to the water supply version, but they are all the same, really.
Jabsco PAR 36800 Belt Driven High Pressure Water Pump [36800-1000]
http://seabornemarine.com/jabsco-par...mp-36800-1000/
The cut-out pressure is 40 PSI.
Flow is 3.3 GPM.
I am considering swapping the supply pump and this drain pump (after cleaning ) as it is quiet and the filter will protect the other pump.
No problem with the belt driven pump.
Perhaps the bilge pump does not have the pressure switch where the supply pump does.
They are pretty expensive, but I found mine as a used pull out.
Old 09-24-2020, 09:00 AM   #6
ThomasC's Avatar
Trailer: BigFoot 25B25RT
Massachusetts
Add a tank to smooth out the pulsations, and mount them in rubber. I have heard that mouse pads work well. I did this in my old camper and it cut the sound way way back. I have a tank for my bigfoot that I haven't installed yet.
https://www.amazon.com/SHURFLO-182-2...%2C257&sr=8-40
ThomasC is offline   Reply With Quote
Old 09-24-2020, 09:09 AM   #7
Remount the pump using a rubber pad under it.
If it is loose or making excess noise from vibration then fix it.
If it is just the normal sound of the pump running, ignore it... after all the pump only runs momentarily with each use.
Watch what you store next to the pump, some objects can amplify even a small vibration. Check for loose tiedowns or brackets which could pick up harmonics.
Old 09-24-2020, 09:38 AM   #8
The accumulator aids in reducing short cycling of the water pump.
I have had one since I rebuilt my Scamp, but the pump I have for on board water pressure bleeds back through it slightly and the pump runs occasionally to build back pressure. It also tends to have city water fill the onboard tank and actually over flow it through the vent. Kind of an unwanted self filling "feature".
Old 09-24-2020, 09:47 AM   #9
AC0GV's Avatar
Wisconsin
Accumulator Tank
[QUOTE=ThomasC;794383]Add a tank to smooth out the pulsations, and mount them in rubber. I have heard that mouse pads work well. I did this in my old camper and it cut the sound way way back. I have a tank for my bigfoot that I haven't installed yet.
This will help the short cycling when using a low flow, like brushing teeth etc. Sometimes you can get the water you need without even turning the pump on. Don't forget to order the PEX parts.
Heater noises hellokerry Hi, I am.... 10 01-15-2018 06:53 PM
1978 surfside waterpump Erik F Problem Solving | Owners Helping Owners 2 12-30-2016 01:12 PM
84 fiberstream Waterpump/water heater question Cyndivg11 Plumbing | Systems and Fixtures 8 05-14-2012 10:38 AM
