07-30-2020, 06:09 PM
Tacoma
Packing the bearings?
Hi! We bought a 1970 Boler on Craigslist and now we’re supposed to pack the bearings and I have called a few auto mechanics and a few RV service places and they’ve told me it’s too old and they won’t do it. Is this normal? I’m in Tacoma. Should I keep calling places or should we try to figure out how to DIY it?
07-30-2020, 06:57 PM
Trailer: Roamer 1
Smith Valley, Nevada
Trailers don't get "too old" for bearing repacking.
And yes, you should learn how to do it yourself. Essentially, you'll remove the wheels and hubs, remove the seals and the bearings. Thoroughly clean the bearings in solvent, inspect them for damage, and if in good shape, repack them. Clean out the old grease from in the hub and install new seals. The races don't need to be removed unless they are damaged or you are going to replace the bearings. You can pull out the seals and go to NAPA, or etrailer to get new ones. Don't try to re-use the old seals. Use a quality grease, like Lucas Red and Tacky, for instance
There is more to it than that, but those are the high points.
07-30-2020, 08:20 PM
Trailer: 2013Escape 21
Iowa
Help
There must be several hundred if not several thousand people in Tacoma that understand Wheel bearings better than the rookie mechanics you have contacted. Go to a car show and ask around and I’m sure you’ll get either offers to help you show you or a recommendation of someone who will do your work for a reasonable price. That’s my take.
Iowa Dave
07-30-2020, 09:00 PM
Trailer: 1979 Boler 1700
Any utility trailer shop will re-pack bearings, replace bearings, service the brakes (if your trailer has brakes), replace the axle, replace leaf springs, etc. Or you can do it yourself. The parts are available at any utility trailer shop, or at etrailer dot com and other online sources.
07-30-2020, 09:07 PM
There is a tutorial on E-trailer. Also find any old guy with handy skills to learn the nuances from as he supervises.
It certainly is NOT normal.
Try a boat place. Your bearings the same as a boat trailer. maybe they can do it for you.
If your trailer is before the 1990s be sure and check the spindle size.
1970s and some 1980s have a straight 1" spindle... newer than that would have 1-1/16" spindles .
Clean your bearings and check the part #s.
New bearings with seal will be in blister packs at your local boat shop if you need them, which is not likely.
07-31-2020, 02:47 PM
Question - so what impact does extended sitting have on the bearings ? Should we worry?
Thanks - John - Colorado Springs
07-31-2020, 06:11 PM
Trailer: 2013 Escape 19
I never worry about stuff like this, just do the maintenance. Life is too short to waste energy worrying. Bearing repacking is an annual maintenance task. Many don't do it annually, but that is the standard recommendation.
Its one of those pay me now, or pay me a lot more later kind of thing. Easy to do yourself, plenty of you tube videos. If neglected they could lead to an expensive failure.
07-31-2020, 06:20 PM
When a trailer is towed often, the grease gets circulated and warmed up.
This helps prevent condensation build up in the hubs and keeps the grease stirred up.
Moisture can cause rust which can cause spalling over time.
Especially on larger trailers, extended setting in one spot can actually stress the bearings just from the weight.
The word Extended is not precise but it would mean more than a few months, depending on the conditions of storage.
Typically , for instance a utility trailer which has been left outside in the yard and exposed to the elements without being used for more than a year sometimes longer is likely to suffer some damage, which will accumulate over several storage periods.
Tires suffer from long term parking as well for some of the same reasons.
If you have good storage for your Fiberglass camper and use it a few times a year , then sitting is not generally an issue.
08-01-2020, 04:45 AM
Trailer: 2015 Escape 5.0TA
After reading this thread, the moronic BS some people tell others just boggles my mind. I mean “too old?” Give me a break!
10-25-2020, 10:11 AM
Trailer: Escape
Spindle Bad
I packed the bearings on 1 wheel yesterday and the spindle looks damaged to me. What do others think?
10-25-2020, 11:15 AM
Yes, Way to many cooks in the kitchen that give advice they really don’t know anything about. Just like, I read it on the internet it must be real.
10-25-2020, 11:32 AM
Perhaps when they say "too old" they are anticipating more problems than they want to deal with. In that case, it really is too old.
10-25-2020, 11:53 AM
Not sure whether the spindle is OK or not. To get a professional opinion, I suggest Les Schwaub. They have repacked the bearings and checked/replaced tires on my 1942 utility trailer and on my 1970 Campster.
They were amused that they found felt seals on the utility trailer. They hadn't seen those in 20 or so years. Guess it was time to get it done.
10-25-2020, 12:09 PM
It looks salvageable from the picture....
Take a piece of crocus cloth and smooth out any really rough or sharp areas.
They don't have to be perfect as long as the bearing race fits relatively snugly in place. then pack and install your new bearings.
Be sure the spindle is straight and that the inner race on the outer bearing has no more than a few thousandths of slack.
Be sure and replace the races in the hub as well since they may be damaged.
10-25-2020, 12:35 PM
Trailer: 2008 Casita 17' SD
Why on earth would anyone want to service a 50 year old axle? Replace it! It's long overdue, by about 30+ years, for replacement. They don't last forever, and FWIW, I myself wouldn't even trust riding on a 50 year old axle. Just my two cents.
10-25-2020, 01:38 PM
Trailer: 13 ft Boler
No such thing as too old! Maintenance is another matter.
Call a shop that isn't a franchise and make their living from service.
Packing the bearings is simple lots a YouTube vids to learn from.
Fred
10-25-2020, 01:41 PM
Where do you think it is damaged? Looks good to me.
Fred
10-25-2020, 03:05 PM
Trailer: Escape
Ridges
There are pronounced ridges (easier to see if you blow up the picture) in the couple of inches before it tapers down, and then also in the smaller diameter part before the threads. The ridges are not even and appear to have nicks out of them. The retaining nut was on very tight and so I wondered if the bearing had locked up?
10-25-2020, 04:07 PM
You will sleep better just going ahead and replacing the parts (Both Sides)
10-25-2020, 05:34 PM
There's only 3-4 spots anything contacts the spindle
1) the inner seal face needs to be smooth to seal
2) inner bearing face needs to accept the bearing race
3) outter bearing face needs to accept the bearing race
4) threads need to accept a nut.
The spindle needs to be decent straight.
Was there any problem with the wheel rotating before disassembly?
I doubt there is a problem with the spindle, problems are generated by lack of or improper bearing maintenance.
Fred
