paint or gel coat?? - Fiberglass RV
Old 07-03-2019, 11:37 AM   #1
Brian Dale's Avatar
Trailer: HUNTER
Kansas
paint or gel coat??
[1972 compact jr] input needed is this a trailer that has been painted multiple times or does anyone know if a "primer" was used under gelcoat? I bought the trailer with the dark blue as you see in the photo(too dark to be the pastel colors originally used) but when I began sanding there was a tan color under the blue -see picture
And then under the tan was a bold and beautiful red. Any chance my jr was originally a red? I've seen a couple hunter II trailers that were red, but as far as I knew the jr's were all pastel pink,blue, green and yellow from the factory. I'd appreciate everyone's input Click image for larger version
ID:	130110Click image for larger version
ID:	130111Click image for larger version
Brian Dale is offline   Reply With Quote
Old 07-03-2019, 01:43 PM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
A couple of years ago I saw a Hunter camper with the original gelcoat, and guess what? It was a darkish red similar to your photos. So you might try stripping off the paint using a gelcoat-friendly stripper. Some people paint over gelcoat because they want a different color, while others paint over gelcoat to hide fiberglass repairs.
Old 07-04-2019, 09:46 PM   #3
Brian Dale's Avatar
Trailer: HUNTER
Kansas
Thank you for replying, that's good to know, as I'd rather restore the gelcoat vs painting. Do you happen to remember if it was a compact II or compact jr? I'll look into a stripper compatible with gelcoat. Happy 4th
Old 07-05-2019, 07:00 AM   #4
Brian I didn't notice which model. I saw it at a Tin Can Tourists rally, and it was the only molded fiberglass camper there. The rest were canned ham and Airstream style campers.
Old 07-05-2019, 07:46 AM   #5
The Hunter definitely came with a red gelcoat, at least on the bottom: http://www.fiberglassrv.com/forums/f...res-40016.html
Old 07-05-2019, 08:42 AM   #6
The Hunter that I saw at the TCT rally was red gel coat all over, not two tone. It was a deep, dark, aged red.
Old 07-05-2019, 09:18 AM   #7
Trailer: 1983 Casita & 1972 home-built
Gelcoat is basically colored polyester resin you catalyze and apply just like the structural layers. There is no need to use a primer; it's all the same stuff.
If you want to add structural layers over existing gelcoat or fiberglass, just sand/grind down through the UV-damaged layer or just remove the high-gloss imparted by the mold surface so you have a chemically clean, rough, fairly flat surface to apply more fiberglass resin and cloth to. You don't have to take all the gelcoat off to get a good bond.
ARVZ is offline   Reply With Quote
Old 02-28-2020, 07:34 PM   #8
Trailer: hunter compact
Try looking inside the camper under the seat area or behind a cabinet. You may be able to identify over spray or the original gel coat. Also try looking in the wheel wells and under the body there are large panels under the floor that I doubt anyone would repaint when they are repainting since you would not be able to see it. They may have covered it with undercoating that you could strip back.
roadsterswap is offline   Reply With Quote
Old 02-29-2020, 05:00 AM   #9
Trailer: Trails West
It is interesting to see and understand how molded fiberglass shells are made. So below is a video tour of the process.
when a molded fiberglass trailer is made inside the mold first thing that goes onto the sides of the mold is a release agent. That is not part of the finished surface. The next thing done to the mold is to coat it with the gel coat material. That is sprayed on in a thin layer. After that the "chop" which is resin mixed with chopped up strands of fiberglass threads is sprayed into the mold. Then it is left in the mold to cure before taking the parts out of the mold. So the gel coat amd the fiberglass structure are bonded together layers.
Go to 12:00 minutes on this video to see Gel coat being applied inside of a boat mold. Same process is used for the molded fiberglass trailers. Note the very bright red and green colors on the inside of the molds, that is the release agent that was applied to the mold so that the shell can easily come out of the mold after curing.
This video shows the "chop" being applied over the gel coat layer. It gets sprayed on with a special gun that cuts and mixes the fiberglass strands into the resin. Then another worker follows behind with a roller to compress and even out the sprayed on layer.
Old 04-26-2020, 01:14 AM   #10
Brian Dale's Avatar
Trailer: HUNTER
Kansas
Interesting indeed! Thanks KC for posting the video. How's the Campster coming along? I've really enjoyed following along as you documented the progress. And thank you to all the others for taking the time to reply
paint
Test to see if it is Gel coat or paint Nelmes Problem Solving | Owners Helping Owners 7 06-15-2014 08:42 AM
Automotive Paint over Gel Coat Problem Str8781 Problem Solving | Owners Helping Owners 19 02-04-2014 09:24 PM
Gel Coat Repair Tutorial Legacy Posts Care and Feeding of Molded Fiberglass Trailers 13 05-28-2007 06:38 AM
GEL COAT REPAIR PRODUCTS Legacy Posts Care and Feeding of Molded Fiberglass Trailers 4 05-08-2007 12:04 PM
Gel coat troubleshooting Legacy Posts Care and Feeding of Molded Fiberglass Trailers 1 01-20-2003 06:05 PM
