Paint Stove - Page 2 - Fiberglass RV
Old 10-28-2016, 12:01 PM   #21
Trailer: Trails West
Paint will give off some fumes when you first put some high heat on the stove. That is normal and the thing to realize is that will stop giving off fumes after it has reached some high temperatures over several cycles of being heated.
So the thing to do is paint it, let it cure for a week or so. Turn on the stove, let it get good and hot, open the windows and doors and let it fume. Do this step several times before you go camping.
You don't notice the fumes on items that have had enamels applied in a factory as they have already been cured in an oven at high temperatures so the fume generating part of the paint cure was already done at the factory before you used the product.
So don't let the concept of the paint producing some fumes at the first few uses stop you from repainting the stove. It is not going to be a constant thing, it is just a temporary situation that is part of the paint cure. Expect it to happen, it is OK for it to happen, just ventilate and don't be inside the trailer while it is going on.
If you paint a woodstove or Bar-b-que or even a car engine it does the same thing of producing fumes while baking in the finish at first.
The only problem I have had with painting a stove top is when using the color white. It yellowed over time in the areas around the burner where the temperature was the highest. So I would recommend a darker color if you want to avoid that yellowed look.
Old 10-28-2016, 08:52 PM   #22
Trailer: 13 ft Scamp 1977
PAINT STOVE
This has been a fascinating discussion. I am grateful for all the input. Today I purchased a can of Stove Bright spray paint (sky blue) and will spray it on the stove top as soon as I get a clear sunny day with no wind.
Will send photos and report back.
Eileen Banashek is offline   Reply With Quote
paint
Interior Paint--Remove or Paint Over Lora Care and Feeding of Molded Fiberglass Trailers 7 12-15-2014 11:30 PM
Paint over resin paint? Joan of Shark Modifications, Alterations and Updates 4 08-02-2014 08:25 AM
Insulation - to paint or not to paint? Trillium.Stella Problem Solving | Owners Helping Owners 23 09-04-2012 10:46 PM
To sand and paint, to paint, or to leave it be...these are the questio JenPB Care and Feeding of Molded Fiberglass Trailers 8 12-07-2008 11:39 AM
To paint or not to paint andrew ferguson Care and Feeding of Molded Fiberglass Trailers 8 08-14-2007 07:02 PM
