08-03-2015, 06:24 PM
#21
New Jersey
It's ok Brian lol...I am fairly certain Chandler didn't have these designed from scratch and after looking at some pictures I get some ideas...I am sure they could be made...and probably not insanely expensive either.
deryk
08-03-2015, 07:09 PM
#22
Trailer: Parkliner 2014
Wisconsin
Brian and Deryk
I believe that if the upper and lower brackets are reusable then all you need is to remove the top half of a flex socket (as oriented in the attached pic) and machine a barrel pin to peg into the square hole on the socket. The cross pin hole should align to the lower bracket.
My washers seem to be in pristine condition so perhaps they did switch material and upgrade to a better socket
I really can't complain so far about the action of the door. The movement is smooth and it latches effortlessly. I will keep an eye on it though.
Sid
08-03-2015, 07:14 PM
#23
New Jersey
Thanks Sid!
I have 4 rusty washers on mine....maybe one day when I have a friend around to help me get the door back on I might try swapping the washers out with something better then the probably mild steel that they are....and take a good look at what is there and how it is put together.
deryk
deryk
08-03-2015, 07:27 PM
#24
08-03-2015, 07:50 PM
#25
Trailer: Class A Motorhome
Well Gee-Whiz...If's it's Craftsman can't you just take it back to Sears?
08-03-2015, 08:42 PM
#26
Wisconsin
Hmmm
08-03-2015, 08:45 PM
#27
LOL
08-03-2015, 08:57 PM
#28
New Jersey
Ken I am not seeing your images (3)
deryk
08-03-2015, 09:03 PM
#29
Have to be logged in on my end. Im on a desktop. You ever Hear from harry or keep in touch? He sure was an interesting guy. Wondered what he went to after your trailer. Or into some other hobby, maybe back to sailing.
08-03-2015, 09:04 PM
#30
New Jersey
never really kept in touch, so not really sure.
deryk
08-16-2015, 08:50 AM
#31
Trailer: Parkliner; 2013 Honda Ridgeline
Originally Posted by stevebaz
If it were mine I would take the hinge apart and wire brush everything. I would replace the washers with 316 series stainless steel washers. I would repaint the hinges with quality paint. Before reassembling the hinges I would spray everything with BIOSHIELD T9. I use this on my salt water boat motor and its really good stuff.keeps all external corrosion at bay. I would respray those hinges again every few months just because replacing might be impossible in the future.
Why Boeshield | Boeshield T-9®
This really sounds like a prudent option. A thorough cleaning, repainting and stainless washers sprayed by Boeshield T-9 with periodic re spraying thereafter should work. We have had boats in salt water for many years and lived aboard and cruised the Atlantic coast for several years. Boeshield T-9 was the best anti-corrosive we found.
08-19-2015, 03:03 PM
#32
Trailer: Shopping
It was related to me during my visit to the previous Parkliner "factory" that the U-joints used in the hinges are actually socket wrench u-joints so a replacement may not be quite so difficult. Go to Sears and get a couple! See if a local machinist can remove the old ones and install the new ones.
08-19-2015, 03:35 PM
#33
Actually it was mentioned earlier that one was marked "Kobalt 377347" which is a Home Depot tool trade name. See Posts 15 & 22.
Actually that fix would only result in the problem coming back again because welding a new u-joint in place will burn off the plating. What's needed here are a some stainless steel components, at least at the flex pivot points.
08-19-2015, 03:56 PM
#34
Has anyone ever seen a flexible socket used as a door hinge on anything else ever??? If not, I guess one could call it innovative, or it could just be a quick and easy way to hang a door without having to worry about accurate hinge alignment in the short term, at least until components start rusting. Interesting concept, curious motives....
08-19-2015, 04:03 PM
#35
Wisconsin
Bob,
I may be mistaken but from the looks of mine no welding would be necessary if you reused the cross pins.
Sid
08-19-2015, 04:40 PM
#36
Originally Posted by Sid
Bob,
Sid
Yep, I think that it was an earlier suggestion to get new pivot blocks made of stainless steel and put them in with stainless steel roll pins. And be sure to get all of the existing rust out of the original welds etc. Ordinary tool steel will rust from exposure to the elements.
if you can't get rid of what's rusting it will return, it's the nature of the beast.
08-19-2015, 04:42 PM
#37
Look at how doors on commercial aircraft swing closed. I have seen several variations on the U-Joint hinge in that application. I will check out the 737 and the Dash-8 doors next week and report back
08-19-2015, 05:38 PM
#38
I never noticed! Perhaps Parkliner simply borrowed the concept from the aircraft industry. Who'da thunk it.....
08-27-2015, 11:55 AM
#39
Parkliner door hinges
Thanks, Frank.
That is very useful information. Washer replacement and regular treatment with Boeshield will hopefully keep the rust at bay.
08-27-2015, 12:22 PM
#40
Trailer: 2014 Parkliner 2016 Honda Pilot
Amazon carries it, in case you don't find it locally, Bill. ( http://www.amazon.com/gp/product/B00...?redirect=true
My hinges are just starting to rust at the top. Have ordered some of the lubricant. Note that the rust removal t-9 will "dull paint" per one of the Amazon Q&As.
-- Anne
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Trillium windows hinges
Legacy Posts |
1 |
04-29-2003 04:23 PM |
hinges - for Ches
Legacy Posts |
1 |
04-26-2003 12:59 PM |
Hinges,catches,etc. resource
Legacy Posts |
3 |
10-02-2002 03:21 PM |
