Parkliner Question - Fixing Leak in Gray Water Tank - Fiberglass RV
Old 10-09-2020, 10:52 AM   #1
Trailer: Currently Shopping
Wisconsin
Hi Everyone,
I am considering buying a 2013 Parkliner fiberglass camper. The current owner said it has a small drip on the gray water tank underneath. Is that hard to fix? Could that have caused water damage in places that can't be seen? Is the gray water tank outside the fiberglass?
We have to drive 500 miles to get it, so I want to know ahead of time what is involved in the repair.
Thanks you so much!
Jennifer
Jennifer 8 is offline   Reply With Quote
Old 10-09-2020, 11:34 AM   #2
Sid
Sid's Avatar
Trailer: Parkliner 2014
Wisconsin
Jennifer,
I have never had a leak from our tank. The only one I can recall hearing about was from a unit that had been in a accident that required a replacement tank.
A word of advice, before you make the trip make sure this unit is accident free.
Sid
Sid is offline   Reply With Quote
Old 10-09-2020, 11:42 AM   #3
Sid
Sid's Avatar
Wisconsin
Pm also sent
Old 10-09-2020, 11:58 AM   #4
Wisconsin
Thanks so much for sharing this information. Excellent idea to ask about accidents. Since I am lucky enough to be communicating with a Parkliner owner, do you think a Toyota minivan with a 3500 tow capacity could pull the camper? Thanks!
Old 10-09-2020, 07:17 PM   #5
Is the tank leaking or is one of the fittings leaking? If the tank is damaged or cracked it would be a more difficult repair. A fitting leak MIGHT be very simple.
Old 10-09-2020, 07:37 PM   #6
IDK anything about Parkliners except for the company history, which if you dont know.. is worth knowing about.
I expect a 3500 lb tow rating will be OK, but I would ask the seller to get a certified scales weight ticket (one way or another before the final sale). Assuming its unloaded, with a tug rated at 3500 lbs I would want to see a trailer weight of no more than about 2600.. maybe 2700 lbs if I were a solo traveler without too much gear.
If the leak is under the floor then it should not be a big problem. Maybe no more than a few hundred dollars to repair. But any leaks that are inside and might have damaged the interior would be a bigger concern. Anytime a seller discloses something like a leak I assume it is one of two possibilities. .. 1., its a major problem that he or she is trying to minimize, or 2... its a minor problem and the seller is being overly cautious. #1 is bad.. # 2 is good!
Old 10-09-2020, 11:31 PM   #7
tractors1's Avatar
Trailer: Escape 21 - Felicity
Have the owner send pics of the leak as it drips. If just a fitting, easy fix. If a hole in the tank, still not a hard fix - might need a patch.
Charlie Y
Old 10-10-2020, 05:27 AM   #8
Trailer: ParkLiner
Virginia
Parkliner has only a black water tank. I guess if it doesn't have a toilet, it might be considered gray water.
Huck is offline   Reply With Quote
Old 10-10-2020, 08:55 AM   #9
Wisconsin
Good call on the accident question. Once I asked, he said he thinks someone before him backed it into something damaging the tank. Thanks!
Old 10-10-2020, 09:24 AM   #10
Sid
Sid's Avatar
Wisconsin
Jennifer
If it is the unit I think it is then my advice is to keep looking.
Sid
Old 10-10-2020, 09:30 AM   #11
Sid
Sid's Avatar
Wisconsin
Another PM sent
Old 10-10-2020, 09:55 AM   #12
Yes, the Sienna should be OK.
You will need a high rise ball mount to bring the high ball to the right height.
Also a brake control and 7 pin connector.
Extension mirrors on the van are good to have too.
Old 10-10-2020, 10:00 AM   #13
Trailer: Parkliner 2013
Grey Water Leak in Parkliner?
Identifying the source of the leak will be important. We had a similar, very slow, leak after a small bump in the rear. It was in the fitting between the on-board water tanks. Chandler told me that this was not uncommon in units with two water tanks as assembly of the second tank was very awkward. We had the starboard tank removed which resolved the leak.
If the leak is in the black/gray water tank (Huck is right, there is only one) you have a larger problem as that tank was custom made for Parkliner and replacements are not available although I'm sure a clever mechanic could fit something in there. I don't have a clue about patching the current tank. Would it be possible to collect some of the dripping fluid and have it tested? That could indicate whether the leak is from the damaged tank or simply from the fresh water system.
Our 2012 Nissan Frontier tow vehicle is rated for 5000 pounds and has plenty of capacity. It does slow down a bit on lengthy uphill pulls, however. If you want to use your Toyota Minivan you should make sure that you have extra cooling for the transmission and possibly a larger-than-standard radiator as well.
Best regards,
Bill
Bill Berry is offline   Reply With Quote
Old 10-10-2020, 10:21 AM   #14
Wisconsin
Hi Bill,
Thanks so much for all the very helpful information. I really appreciate it.
Best wishes.
Old 10-10-2020, 10:39 AM   #15
Wisconsin
Thanks Wayne!
Old 10-10-2020, 10:57 AM   #16
2106 Parkliner
How about a newer Parkliner with no leaks?
And it's just across the river from the S.W. corner of Wisconsin?
Give us a call at 563 258 3085
Old 10-10-2020, 01:18 PM   #17
Trailer: ParkLiner
Virginia
Originally Posted by Wayne Collins View Post
2106 Parkliner
Does it come with a flux capacitor?
Old 10-10-2020, 03:34 PM   #18
What's a "FLUX CAPACITOR? And why would you want one?
I know that flux is what you use when soldering.
and that a capacitor is like and electronic battery.
Old 10-10-2020, 03:39 PM   #19
Trailer: ParkLiner
Virginia
Since it's a 2106 Parkliner, I figured it needed a "Back to the Future" flux capacitor to get back here from the future!
Old 10-10-2020, 03:42 PM   #20
Oops, that would be a good trick, wonder what 2106 will be like.
Don't expect to live that long though.
parkliner
gray water drain leak Tom Smayda Problem Solving | Owners Helping Owners 1 06-13-2013 01:58 PM
Gray water tank for '91 Casita Geoffrey Cobb Problem Solving | Owners Helping Owners 1 10-11-2007 11:38 AM
Gray water w/out tank Janine Problem Solving | Owners Helping Owners 10 08-29-2007 03:06 PM
Gray Water Tank Leaking Legacy Posts Problem Solving | Owners Helping Owners 6 06-02-2003 10:04 PM
