10-09-2020, 10:52 AM
Trailer: Currently Shopping
Wisconsin
Parkliner Question - Fixing Leak in Gray Water Tank
Hi Everyone,
I am considering buying a 2013 Parkliner fiberglass camper. The current owner said it has a small drip on the gray water tank underneath. Is that hard to fix? Could that have caused water damage in places that can't be seen? Is the gray water tank outside the fiberglass?
We have to drive 500 miles to get it, so I want to know ahead of time what is involved in the repair.
Thanks you so much!
Jennifer
10-09-2020, 11:34 AM
Trailer: Parkliner 2014 V6 Jeep Cherokee
Wisconsin
Jennifer,
I have never had a leak from our tank. The only one I can recall hearing about was from a unit that had been in a accident that required a replacement tank.
A word of advice, before you make the trip make sure this unit is accident free.
Sid
10-09-2020, 11:42 AM
Wisconsin
Pm also sent
10-09-2020, 11:58 AM
Wisconsin
Thanks so much for sharing this information. Excellent idea to ask about accidents. Since I am lucky enough to be communicating with a Parkliner owner, do you think a Toyota minivan with a 3500 tow capacity could pull the camper? Thanks!
10-09-2020, 07:17 PM
Is the tank leaking or is one of the fittings leaking? If the tank is damaged or cracked it would be a more difficult repair. A fitting leak MIGHT be very simple.
10-09-2020, 07:37 PM
IDK anything about Parkliners except for the company history, which if you dont know.. is worth knowing about.
I expect a 3500 lb tow rating will be OK, but I would ask the seller to get a certified scales weight ticket (one way or another before the final sale). Assuming its unloaded, with a tug rated at 3500 lbs I would want to see a trailer weight of no more than about 2600.. maybe 2700 lbs if I were a solo traveler without too much gear.
If the leak is under the floor then it should not be a big problem. Maybe no more than a few hundred dollars to repair. But any leaks that are inside and might have damaged the interior would be a bigger concern. Anytime a seller discloses something like a leak I assume it is one of two possibilities. .. 1., its a major problem that he or she is trying to minimize, or 2... its a minor problem and the seller is being overly cautious. #1 is bad.. # 2 is good!
10-09-2020, 11:31 PM
Trailer: Escape 21 - Felicity
Have the owner send pics of the leak as it drips. If just a fitting, easy fix. If a hole in the tank, still not a hard fix - might need a patch.
10-10-2020, 05:27 AM
Trailer: ParkLiner
Virginia
Parkliner has only a black water tank. I guess if it doesn't have a toilet, it might be considered gray water.
10-10-2020, 08:55 AM
Wisconsin
Good call on the accident question. Once I asked, he said he thinks someone before him backed it into something damaging the tank. Thanks!
10-10-2020, 09:24 AM
Wisconsin
Jennifer
If it is the unit I think it is then my advice is to keep looking.
Sid
10-10-2020, 09:30 AM
Wisconsin
Another PM sent
10-10-2020, 09:55 AM
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
Yes, the Sienna should be OK.
You will need a high rise ball mount to bring the high ball to the right height.
Also a brake control and 7 pin connector.
Extension mirrors on the van are good to have too.
10-10-2020, 10:00 AM
Trailer: Parkliner 2013
Grey Water Leak in Parkliner?
Identifying the source of the leak will be important. We had a similar, very slow, leak after a small bump in the rear. It was in the fitting between the on-board water tanks. Chandler told me that this was not uncommon in units with two water tanks as assembly of the second tank was very awkward. We had the starboard tank removed which resolved the leak.
If the leak is in the black/gray water tank (Huck is right, there is only one) you have a larger problem as that tank was custom made for Parkliner and replacements are not available although I'm sure a clever mechanic could fit something in there. I don't have a clue about patching the current tank. Would it be possible to collect some of the dripping fluid and have it tested? That could indicate whether the leak is from the damaged tank or simply from the fresh water system.
Our 2012 Nissan Frontier tow vehicle is rated for 5000 pounds and has plenty of capacity. It does slow down a bit on lengthy uphill pulls, however. If you want to use your Toyota Minivan you should make sure that you have extra cooling for the transmission and possibly a larger-than-standard radiator as well.
Best regards,
Bill
10-10-2020, 10:21 AM
Wisconsin
Hi Bill,
Thanks so much for all the very helpful information. I really appreciate it.
Best wishes.
10-10-2020, 10:39 AM
Wisconsin
Thanks Wayne!
10-10-2020, 10:57 AM
Trailer: Parkliner
Iowa
2106 Parkliner
How about a newer Parkliner with no leaks?
And it's just across the river from the S.W. corner of Wisconsin?
Give us a call at 563 258 3085
10-10-2020, 01:18 PM
Trailer: ParkLiner
Virginia
Originally Posted by Wayne Collins
2106 Parkliner
Does it come with a flux capacitor?
10-10-2020, 03:34 PM
Trailer: Parkliner
Iowa
What's a "FLUX CAPACITOR? And why would you want one?
I know that flux is what you use when soldering.
and that a capacitor is like and electronic battery.
10-10-2020, 03:39 PM
Trailer: ParkLiner
Virginia
Since it's a 2106 Parkliner, I figured it needed a "Back to the Future" flux capacitor to get back here from the future!
10-10-2020, 03:42 PM
Trailer: Parkliner
Iowa
Oops, that would be a good trick, wonder what 2106 will be like.
Don't expect to live that long though.
