Originally Posted by MelVee
I hooked up to shore and water gushed below the sink. So it was obvious (I’m pretty embarrassed to admit) the drain was not connected to a hose. But I’m still at a loss as to why I can’t get any water from the fresh water tank to the manual pump dispenser.
I'm going to assume that when you turned on the faucet, water gushed below the sink not when you hooked up shore water and opened the valve at the stand. I also assume you filled up the fresh water tank. It has a separate fill port and is not filled just by hooking up to shore water.
Have you checked to make sure the line that is connected to the hand pump runs all the way and is connected to the fresh water tank? What, if anything, do you hear when you work the manual pump?
