Originally Posted by TheWanderers
We're renovating the few things that are required in Gladys (88 Bigfoot fifth wheel) and I've been thinking about a comment that Laura made about replacing our LP heater with an electric model.
I have been looking at Class B conversion vans as an alternative tow vehicle. Several of them have the Rixen version of the Espar Diesel Fuel Heater that both heats the van with about 1/10 to 1/4 gallon per hour of diesel and also very quickly heats hot water and can provide circulating heated antifreeze fluid to keep the water pipes from freezing. The catch is that you have to have a diesel powered vehicle. Has anyone ever installed one of these heaters on a travel trailer? They were originally designed for cab heaters for tractor trailers (that also run on diesel fuel). Does it work for travel trailers.
see:
http://rixens.com
They say
"The basic functionality of the system is explained here. The system coolant (water/antifreeze) is heated by the Espar heater. The hot system coolant circulates through the system, heating the Domestic water supply on demand, and then through the air handler to complete the circuit. Additionally the system coolant can be heated with shore power using the AC element."
Walk in Peace,
Scribe with a Stylus
