Porch Light Problem - Fiberglass RV
Old 07-05-2010, 10:35 PM   #1
Perry Mac Donald's Avatar
Trailer: 1974 13 ft Boler (built in Earlton
Last year i had some help rewiring my trailer running lights and once i got the hang of it i tackled the interior lights . Everything works fine except for the porch light , i always blow fuses . I used #12 wire for both runs neg and pos . What would be the correct way of doing it properly . The switch is seperate from the light , i think my problem lies with the way i wired the switch . Can someone please help me sort this out . Also what amperage of fuse do i use .
Perry Mac Donald is offline   Reply With Quote
Old 07-05-2010, 10:44 PM   #2
Roy in TO's Avatar
Is the switch on either the -ve or +ve? Not both?
What else is on the circuit?
Old 07-05-2010, 11:29 PM   #3
Flygal's Avatar
Trailer: 77 Scamp
is it on a switch (besides the one on the porch light?)
Flygal is offline   Reply With Quote
Old 07-06-2010, 11:30 AM   #4
I have both black and red wires running from the light to the switch on the wall inside , to the two terminals on the back of the switch . Should the black wire bypass the switch and go directly to the ground ?
Old 07-06-2010, 11:31 AM   #5
Yes it is seperate from the light .
Old 07-06-2010, 03:07 PM   #6
Joe MacDonald's Avatar
Trailer: 1981 Trillium 5500
Perry, the negative wire should go straight to the light, and it connects to the shell or outer part of the socket.
The positive goes to the switch then from the switch to the centre pin on the light socket.
Joe
Old 07-06-2010, 03:36 PM   #7
I finally fixed the problem .
Old 07-06-2010, 11:20 PM   #8
Roy in TO's Avatar
Thanks Joe,
I always get them mixed up, now I have a way to remember.
Postive to the Power switch to the Pin. 3P's in a pot.
The negative is a straight line just like on the battery (-)
Old 07-07-2010, 02:04 PM   #9
Joe
It works great now , but what amp fuse should i use ? There is nothing else on the circut . Thank you all for your expertise .
Old 07-07-2010, 05:27 PM   #10
2 or 3 amps should be fine, if you used #14 wire you could go as big as a fifteen, but I tend to stay on the conservative side myself.
Joe
lighting, lights, porch light
3-Way Porch Light peterh Modifications, Alterations and Updates 23 01-21-2011 04:43 PM
What do you think of this as a porch light? Donna D. Care and Feeding of Molded Fiberglass Trailers 18 09-21-2010 07:50 PM
Porch Light Kevin K General Chat 15 08-11-2008 01:59 PM
Porch Light Legacy Posts Problem Solving | Owners Helping Owners 8 06-10-2003 10:21 AM
Bad Casita Porch light Legacy Posts Problem Solving | Owners Helping Owners 24 05-07-2003 01:00 PM
