My
Bigfoot 5th wheel systems workthrough continues.
Furnace is up and working, shower no longer
leaks, and the water tank drain valve has been replaced. A week ago (roughly), one
battery was replaced and the other charged completely; the trailer has been plugged into 120 volt since then. I checked the
battery panel yesterday and was surprised to find the batteries in only fair to poor condition (only three lights). Two problems - My MagneTek series 6300A model 6332 is not charging the batteries as it should (it has the
battery charger). Something must be drawing current from the batteries to pull them down. I found the charger info at:
MagneTek Series 6300A Model 6332 and I will reluctantly wade into the power converter, probably to replace a $7 resistor. Any thoughts on where to start searching for the battery draw? While I have a meter, I am an
electrical neophyte.
Thanks for any
light you can shed on this.
Cam
