Prest-o-Fit Sewer Fitting too Loose
I recently purchased a Prest-o-fit blue sewer system with push together fittings. Everything pushes together fine without leakage, but 3 different bayonet end fittings all fit loosely on our trailer sewer outlet. At least loosely enough that the gasket isn’t compressed and liquid shoots out when the dump valve is opened. I tried putting two gaskets on the fitting, but that was too thick to get it attached to the outlet. Our Rhino system had always fit tightly, so I wondered why there was a difference. Any suggestions? Are slightly thicker gaskets available?
