06-06-2020, 08:39 PM
Trailer: 2018 Casita SD; 2017 Toyota Highlander with tow package
Kansas
Problem in high winds
After sustained winds of 30mph and gusts up to 50mph (so my weather app said), I found my front jack cone almost off its block. I've stabilized it for now, and I'll hitch it to the car and reset it when the winds have died down tomorrow. I will not use the block, which does, however give me a level surface on which to put the cone.
Has anyone come up with a good solution for high winds? I did the best I could to point my nose into the prevailing wind, but as you can see, I was off a bit. I do have some partial shielding from a hill on the upwind side.
06-06-2020, 09:02 PM
IllAnnoy
We were at Myrtle Beach where the trees grow sideways in the wind.
Our 13Scamp was pushed about a foot or more over the few days that we were there. The wind kept blowing out our water heater pilot so we had to tie a folding chair to the bumper as a wind break!
We had a good time anyway...
Wheel chocks may help.
BTW... The forty foot motor homes on either side of us didn't seem affected at all, but they did seem to cause a venturi effect and enhance our "wind tunnel
06-06-2020, 09:26 PM
Trailer: 2012 Escape 19
Alabama
We were camped in the Guadalupe Mt last year in March. Forecast was 50 mph winds gusting to 70mph. We left the Escape 19 connected to the truck.
Graham
06-06-2020, 09:28 PM
Heavy rubber wheel chocks.
06-06-2020, 11:57 PM
Trailer: Escape
If that yellow pad in your picture is smooth plastic, I would try something more grippy under your jack stand. I've been using the "Camco 44600 Universal Flex Pads", they are heavy and more textured so the stand doesn't slide as easily.
06-07-2020, 06:23 AM
Trailer: 2015 Escape 5.0TA
I would have to add that I don’t think Bob Dylan was correct! “The answer, my friend, is NOT blowin’ in the wind.”
Very likely everything that has been suggested would help......staying connected, good wheel chocks, and a less slippery jack pad. And then Floyd’s comment comes into play. Have a good time anyway.
06-07-2020, 07:57 AM
South Carolina
i stopped using the cone a few years ago after it separated from the jack on 2 different occasions. i'm now using just the plain old flat jack foot with a stack of a few square plastic pads. i like that the foot can stay attached all the time so i don't need to search for it..
p@
06-07-2020, 09:27 AM
Kansas
Thanks everyone for your suggestions. This is my solution for now. BTW, both my wheels were chocked! At least with this setup, if the trailer moves, it will just roll; it won't fall off the cone. I call it my "rock-chocked" wheel. Heh, heh. I'm a University of Kansas graduate, so Rock Chalk!
goalie39 and CPW: I'll check out that Camco pad and other "less slippery" pads.
P.C.: I don't have a flat jack foot. My unit came with the wheel. I will look into this possibility, though. This is my second cone. I noticed on my first one that it had an end-of-life date on it (Feb 2020), so I replaced it earlier this year.
Jon: I'll look into different wheel chocks. My are the wooden ones used for airplanes. They didn't appear to have failed in any way in this case.
guyill: I might rehook the trailer to the car after I've run some errands in town. I think it will be "level enough."
floyd: Wow! I'm not using my water heater, but I'm sure I would have the same problem. The wind woke me up at 5:30am, which was when I jumped up and repositioned the Casita. It's facing nose into the wind more accurately now, so I hope I'm not scooting around like you were.
06-07-2020, 09:31 AM
Trailer: Casita 17' Spirit Deluxe (aka: Tweaker's Casita)
Southwest Ohio
Originally Posted by goalie39
If that yellow pad in your picture is smooth plastic, I would try something more grippy under your jack stand. ....
Try using a rubber paver. You can get them at Lowes or Menards.
I bought several to use as levelers. Use a utility knife to split a couple of them in half (16" x 8") and stack them up as necessary.
Then, if I have leftovers, I spread them out under the steps to function as a doormat.
Finally, when I visit the dump site, I stack them all up under the curb-side wheel to facilitate the flow out of the grey tank.
06-07-2020, 09:32 AM
Kansas
I bought several to use as levelers. Use a utility knife to split them in half (16" x 8") and stack them up as necessary.
Great solution!
06-07-2020, 10:11 AM
Trailer: 2013 Casita 17' SD
Illinois
When we bought our used Casita several years ago it came with a tongue wheel and this orange tung-n-chock. It has served us well and have had no problems. It is stored with the four chocks when in transit. Had no reason to change to a flat plate...so far.
06-07-2020, 10:17 AM
Kansas
Interesting. Haven't seen one of those before.
06-07-2020, 10:30 AM
Trailer: Happier Camper
Everywhere, USA
Questions
May we know where you are? Winds have been one of our worries since extremes of (wind, rain and storms) were pretty nonexistent where we came from.
The first time we experienced high winds was at the South Dakota rally last year. A tornado was passing through so wind speed was variable and everyone went to the concrete bathroom for shelter (except us, since we didn't know any better). We rode the rocky winds. Wheels chocked, front tongue wheel not chocked, not hooked to the truck. A few trailers moved a bit.
The second time was in Utah in February - just under 30 mph winds. Same scenario as above, wheels chocked, front tongue wheel not chocked, not hooked to the truck. All trailers ok.
Third time was not wind but the 5.7 Utah earthquake in a crowded RV park in March. I happened to be standing in the doorway of the trailer with the door open. I watched our truck next to me bounce and rock side to side and almost flip but the trailer did not bounce and rock as much as the truck. Trailer was fully chocked, including the tongue wheel (although the tongue wheel was turned side to side instead of front to back as in your picture, not sure if that would make a difference). The only thought on why the truck rocked and bounced more may be because the truck has springs and the trailer has a torsion axle? Surveying the aftermath, most all of the other trailers and 5th wheelers in the park (we were the only fiberglass and also the smallest) had their tongues off their blocks. Our trailer did not move.
I have heard there are some trailer parks that have in ground tie downs. Wouldn't it be nice if they all did?
06-07-2020, 10:35 AM
Kansas
I have heard there are some trailer parks that have in ground tie downs. Would it be nice if the all did?
I am in the Apache Sitgreaves National Forest in Arizona at just over 9000ft. You've gone through much more than I have. Haven't had to ride out an earthquake yet.
06-07-2020, 03:20 PM
Trailer: 1993 CASITA 16SD
Good wheel chocks on both sides plus the stabilizers have always worked for me.
06-07-2020, 03:40 PM
Name: Borden and Carole
What a great idea will have to look for this item thanks for showing it
1978 Ontario made Boler
06-07-2020, 05:45 PM
Kansas
Yep, they were all in place.
06-07-2020, 07:17 PM
We carry a large wooden block of wood about 10X10X8 high I think it is a piece of a RR tie. We never put the wheel under the tongue when camping. The tongue kind of gets into a groove in the block when you use it. We've never had any sliding and we've been in some horrible wind in Utah. We actually took the picnic table ,one of the steel ones and laid it on its side a few inches from the trailer in case we blew over. Thought at least maybe we wouldn't go all the way over if we rolled. The tongue never moved on the block and it never has in 13 years. We always chock both tires on front and back and make sure they are tight.
06-07-2020, 07:23 PM
Trailer: 2013Escape 21
Iowa
When my brother in law had a fold down trailer be got in a big straight line wind that turned the trailers out 90 degrees. He told us about the experience an said it would not happen again. The next time we went out he had made a stabilizer for the jack and gave me one too. It was a piece of 2 by 12 that was square so I suppose 11 1/4 on all sides. The he boxed in the top side with smaller Pieces of four by four all lagged together. The jack post went in the center. He had anti slip notches cut on the bottom. In two opposite corners he had 5/8 holes drilled. Those were for two 1/2 inch by about 16 inch rebar stakes with a nut welded on the top. We only drove those in if a storm was on the way. Or If we were staying out for the week. No more spinning in the night. I have seen people put in earth anchors a few times too.
I’ve never had a real problem with our Escape and if bad weather is predicted I stay hooked up to the tow rig.
Iowa Dave
06-07-2020, 09:52 PM
Trailer: Catalina
Maine
Winds and trailer movement
We have a "small older 5th wheel", and no it is not fiberglass but I enjoy following your forum. Started about 4 years ago before we bought.
We were caught in a tornado warning and heavy thunderstorm activity just beyond Columbus, OH in April of 2018 in a campground for the night on the Indiana line I believe and we did not unhook from our 3/4 ton truck. Luckily that site was somewhat downhill as I almost always have to unhook for leveling. The wind blew extremely strong and that camper shook all night long.
There was one other night on our 52 day trip that year that we did not unhook also in New Mexico or Arizona when they were getting strong winds and there was little protection. Other campers at that place recommended remaining being hooked up after I questioned why the 3 or 4 other rigs in that facility were all parked 90 degrees to what management normally allowed. Got a good sandblasting that evening.
I would recommend staying hooked if real heavy winds were predicted.
