Problems with signals on camper trailer - Page 2 - Fiberglass RV
Old 05-17-2021, 05:52 AM   #21
Raz
Raz's Avatar
Vermont
Originally Posted by Glenn Baglo View Post
I could search the net, but I know that once I removed the dielectric grease that my buddy had slathered on the contacts, I was able to get my lights working.
I presume that if the contacts have enough pressure on them to displace the grease, then it works just fine, but in my experience, I'd avoid slathering it on lights and 7-pins.
Battery not charging? Obviously, you need to install larger wires to make up for the high resistance contacts caused by the grease.
Old 05-17-2021, 06:07 AM   #22
Joe MacDonald's Avatar
if your connectors are in good condition, dielectric grease is the ticket, the pressure from the female contacts will displace the grease and make a firm connection on the male on the tow vehicle. if the trailer side is well used, the connectors get spread out, and make a poor connection.
With my Envoy, I found that the factory side of the wiring harness that plugs into the connector had corroded to the point it had to be replaced, I filled it with dielectric when I re-assembled it, and no problems so far.
If dust is a problem, you probably need to replace the cap for the plug.
Joe
Help with wiring to tail lights and side signals Trillium-Pettis Electrical | Charging, Systems, Solar and Generators 21 04-06-2018 12:06 PM
Brake Lights/Turn Signals Not Working (Blowing Fuse) DeanCHS1980 Electrical | Charging, Systems, Solar and Generators 12 05-04-2016 02:13 PM
How do you make turn signals work on side lights? Rusty99 Electrical | Charging, Systems, Solar and Generators 13 05-29-2014 01:10 PM
Best ways to pickup and boost free WiFi signals while in motorhome? magentawave Problem Solving | Owners Helping Owners 9 11-16-2013 10:18 AM
Using side marker lights as turn signals al gilliland Care and Feeding of Molded Fiberglass Trailers 30 08-14-2009 04:53 PM
