Propane leak? - Page 2 - Fiberglass RV
Old 06-15-2019, 12:09 PM   #21
Trailer: 1975 Scamp, 13-foot
Redding, California
Originally Posted by Joe19403 View Post
Notice the description says: "Will not read levels immediately: begins working when propane is flowing"
Harold
Doctor Harold is offline   Reply With Quote
Old 06-18-2019, 09:38 AM   #22
Trailer: scamp
Indiana
does it hold preasure.
The gage you are using says it only measures when there is flow. Obviously once you shut off the valve no flow. The real test is if it will hold preasure.
Turn all of your appliances to off. Turn the valve off and then wait about 10 minutes. Go to the stove and hold a lighter next to one of the burners and then turn it on. OK this does best with two people. What should happen is that the burner will light and then quickly peter out. But it should light. If it doesn't then you have a problem. And as someone here has said, unless you are a really good handy man this is a job for the experts.
If that works then try opening the valve and lighting the stove again and then turning the stove off. Then wait a hour and do the same test. You should get the same result.
That will tell you might more than that meter would.
computerspook is offline   Reply With Quote
propane
Are there any 9V battery propane leak alarms? bcomnes Problem Solving | Owners Helping Owners 6 01-16-2010 08:17 AM
Casita Propane Leak Detector Alarm David A. Problem Solving | Owners Helping Owners 4 02-11-2009 08:26 AM
Propane leak? MountainHome Problem Solving | Owners Helping Owners 6 05-10-2008 10:29 AM
Propane leak? Kate Carney Problem Solving | Owners Helping Owners 3 07-30-2007 07:34 AM
Propane Leak Legacy Posts Problem Solving | Owners Helping Owners 13 04-24-2003 05:26 PM
