Propane not functioning - Page 2 - Fiberglass RV
Old 08-09-2017, 04:36 PM   #21
Originally Posted by Glenn Baglo View Post
I turn on both tanks so that I don't wake up in the middle of the night because the furnace has quit and the fridge isn't running. That's the whole point of auto switch-over. All you have to do is look at the gauge on the switch-over to see when a tank has run empty.
Most tanks do not have a gauge. If so then that would be perfect. A gauge is an add on that most people don't add.
Old 08-09-2017, 04:49 PM   #22
I should have said indicator, not gauge.
When the top half of the window is red, you have an empty tank.
The lever indicates which tank is empty. Turn the lever to the full tank and you can remove the empty one and get it filled.
Old 08-10-2017, 09:25 AM   #23
Tim D.'s Avatar
Trailer: 1986 17 ft Bigfoot
Re fridge
If you are still in Oregon you might try Wayde's Mobile RV repair in Eugene. A few years ago our Fridge was cooling poorly. Wayde put in a rebuilt cooling unit that has worked fine ever since. Wayde was fast and reasonably priced.
Over the years I have had much better luck with mobile rv repair than brick and mortar shops.
Tim D. is offline   Reply With Quote
propane
Fridge working on DC and Propane, but not 110 GregandTeresa Problem Solving | Owners Helping Owners 14 07-01-2015 04:16 PM
Dometic Fridge propane meter not working GMike A Problem Solving | Owners Helping Owners 7 09-21-2014 04:58 PM
Functioning Weep Holes honda03842 Modifications, Alterations and Updates 1 08-28-2014 10:23 AM
propane not flowing pegski Problem Solving | Owners Helping Owners 14 06-18-2014 11:56 AM
Composite (not steel) propane tank Amy M Problem Solving | Owners Helping Owners 8 11-27-2009 05:12 PM
» Trailer Showcase
Casita
Poiny
Purdy
Azurko
