Propane refrigerator that can run with no 12v? - Page 2 - Fiberglass RV
Old 02-16-2021, 09:04 AM   #21
Joe MacDonald's Avatar
my new three way fridge does require 12vdc to operate, there is a gas solenoid, and a digital control panel, a lot of 3 way fridges require power to operate on gas. the 3 way I took out did not, and there are still a few around that don't
If the shell is in good condition, there are places that will rebuild or custom build a cooling section for an older unit.
Joe
Joe
Old 02-18-2021, 04:51 PM   #22
Trailer: Trail Cruiser
I also had the igniter model. Ran off two D-cells,
Old 02-18-2021, 05:10 PM   #23
tractors1's Avatar
Trailer: Escape 21 - Felicity
Originally Posted by matthfam View Post
Unless fitted with a fan, 3-way fridges do not use electric power when running on gas.
Most need 12V to open the gas solenoid that controls propane flow.
Charlie Y
Old 02-18-2021, 05:52 PM   #24
If you mean most built in the last couple of years than I might agree.. but the point made a few times here is that many do not. An absorption fridge that requires no electric at all (such as my 2015 model Dometic 2410) is great to have for extended boondocking or emergency use.
Old 02-18-2021, 06:14 PM   #25
tractors1's Avatar
Ah, then yours must not have the reignitor which does require a battery connection.
Charlie Y
Old 02-18-2021, 06:29 PM   #26
Ah, then yours must not have the reignitor [sic] which does require a battery connection.
true.
And that might be a nice feature if you have a fridge that needs to have the flame restarted because it blows out.. but I don't think mine have ever gone out, even on the highway.
Oh no! I just mentioned that I (sometimes) use my fridge on propane when going down the road.. get ready for the dire warnings!
Oh no, again... I just made a comment implying that there is no risk when using a propane fridge on the highways.
So for the record, IMHO there is minimal risk, and when on the road I avoid using the fridge on propane when I can, and I accept what I am sure is a very small risk when I can't.
Old 02-18-2021, 06:53 PM   #27
Massachusetts
We would get along well if we ever met.
Although I must admit I run my tires at about half the maximum sidewall pressure and I think it's just fine. Because I'm a MADMAN!
AlanKilian is offline   Reply With Quote
Old 02-18-2021, 07:31 PM   #28
Mine also ran on 12 volt DC for traveling.
Old 02-19-2021, 03:15 PM   #29
Joe
Joe
mine has no 12v to the pilot just simple operation. i guess dometic got too many complaints from well wont go into that!
Old 02-19-2021, 03:16 PM   #30
i dont run 1/2 the pressure but i dont run at maximum!
Old 02-19-2021, 03:18 PM   #31
so is this 12v supply running the magnets that keep the valve open? i suppose that is their reasoning?
Old 02-19-2021, 03:22 PM   #32
interesting notes and comments so?
i have the old style dometic how do you clean the burner in that critter?
anyone??
propane, refrigerator
24v or 12v if I want to run an electric fridge. Nik Electrical | Charging, Systems, Solar and Generators 37 10-31-2017 07:07 AM
Run 12V TV/monitor off of 12V outlet or via inverter? Rod Scher Problem Solving | Owners Helping Owners 22 11-19-2016 02:11 PM
What can I run and not run on my home electricity? GregandTeresa Electrical | Charging, Systems, Solar and Generators 21 06-18-2016 06:16 AM
I have a 12v fan I want to run on shore power Dietrich Modifications, Alterations and Updates 8 08-31-2014 07:57 PM
Run both 120 & 12v electrical jimkill Modifications, Alterations and Updates 17 07-31-2013 02:33 PM
