propane regularor - Fiberglass RV
Old 04-23-2016, 06:18 PM   #1
Lionel's Avatar
Trailer: 13 ft Boler
Manitoba
propane regularor
I have a 72 boler.
I plan to change the propane regulator as it is 40 years old. I can purchase most of what I need locally but have a question on installation.
I am going to try to attach a picture.
The hose coming out of the camper is metal. I wish to adjust the pipe a bit and put a new connector on the metal pipe. I will put a rubber hose on it (with the regulator attached) and run it to the tank.
How do I attach the new adapter to the metal pipe?
Thanks
Lionel
Lionel is offline   Reply With Quote
Old 04-23-2016, 06:36 PM   #2
Scamp sells a bulkhead 3/8" double flare fitting to bring the gas line through the shell. The shell fitting makes a good sturdy point to attach your 3/8" flare fitting hose from the regulator. You will have to cut your copper line inside the shell and put a female fitting and flare the copper and attach it to the inside bulkhead fitting. Scamp attaches the single tank regulator to the frame rail with a bracket with screws, then run the rubber hoses from there to the outside bulkhead fitting and tank.
Eddie
propane
Propane tank Level? Byron Kinnaman Problem Solving | Owners Helping Owners 35 12-27-2020 02:27 PM
Propane christineb Care and Feeding of Molded Fiberglass Trailers 12 11-26-2005 10:41 PM
Propane Check Legacy Posts Care and Feeding of Molded Fiberglass Trailers 1 11-19-2002 09:54 PM
Propane wall-mounted heater Legacy Posts Care and Feeding of Molded Fiberglass Trailers 11 11-07-2002 07:47 PM
Propane woes Legacy Posts Care and Feeding of Molded Fiberglass Trailers 11 11-05-2002 04:50 PM
