I'm working on a 1973
cloud I purchased last
fall. Up to trying to get the
propane working. Po never used it and all that was left sticking out the front of the trailer was a broken rubber hose that had the end taped closed, no regulator. I replaced some of the copper and rubber supply line, and checked for
leaks of coarse. Since it only has a stove, small gravity
furnace, and a lantern type
light inside I just put in a 11 pound single stage regulator. The stove works just fine. but the
furnace doesn't put out much heat and the lantern doesn't get very bright. Wondering If I have the right regulator or if I even needed one back in 73.
