03-13-2021, 04:13 PM
Trailer: Bigfoot 25RQ
Mississippi
propane regulator
My propane regulator isn't but is working. The indicator that shows the green or red disk is stuck on red. The tank is full, just filled recently plus the refer and stove will operate. Is there anyway to correct this or just replace the old one. It's going on two and half years, had about three 30 LBS bottles through it.
Whats the average lifespan of these regulators, anyone know?
03-13-2021, 05:55 PM
Trailer: 2017 Escape 17B
Idaho
I’m no expert but if propane appliances are working then your regulator is ok. My red/green indicator never worked. Always stayed green even with tank empty.
03-13-2021, 10:06 PM
I installed a new regulator on general principle. Over ten years old, I don't trust it. The indicator was working just fine.
You say "the tank is full", are there two tanks or one? How many pigtails? Where is the manual selector lever pointing to?
Charles
'03 Ram 2500 CTD and 2008 Bigfoot 25B21RB.. Previous, Being repaired and will be sold, is a 2008 Thor/Dutchman Freedom Spirit 180. SOLD - 2007 Winnebago View 23H Motorhome.
03-14-2021, 07:49 AM
Mississippi
Propane
Thats what I meant it is and isn't working.
Both tanks are full, doesn't matter where the selector is the disk stays red. I always turn tanks off when not in use. I'm not that worried about it just something I found when I do my once a month check of appliances, was thinking the lifespan of the regulator should have been longer.
03-14-2021, 08:33 AM
No idea what is typical, but my regulator and indicator are 18 years old and still work perfectly.
03-14-2021, 09:03 AM
Trailer: 1986 Bigfoot FT20
It will always be red until you turn both tanks back on.
03-14-2021, 11:29 AM
Mississippi
Both tanks
Tried that, plus I never turn both tanks on at the same time. Even with one tank valve open it was always green or red. Green with one open, red after shutting it off.
03-14-2021, 11:30 AM
Mississippi
Bob you know the brand you have? This one is camco.
03-15-2021, 01:13 AM
Everywhere
I think the lifespan of the regulators is highly variable. The one on my Escape never had any problems, but the one on the Bigfoot died after about 18 months. Might depend on conditions like heat, freezing, debris in the lines, etc.
03-15-2021, 09:48 AM
It looks generic, but the tag says "Marshall Gas Controls, a division of SH Leggitt, San Marcos, TX." Came with my new 2003 Casita.
03-16-2021, 05:38 AM
Trailer: ford
mexico
Excuse me, I purchased this Fairview RV Camper LP 2 Stage Automatic Propane Regulator for our new trailer. To feed our gas stove. It has 3/4 gas line it doesn't allow enuff pressure to light the stove. Any suggestions?
03-16-2021, 06:37 AM
3/4” line doesn’t sound right, maybe 3/8”
Stove or grill?
If your feeding a grill with a regulator you can’t have a regulator at the grill also.
Why would a new camper need a new regulator?
Can you provide more info on reason for new regulator?
I’m sure the collective brains here can figure it out.
03-16-2021, 06:44 AM
+10 Very doubtful line is 3/4 inch. More likely 3/8 inch. Look at the hose. I just bought one on Amazon, it is going back. The reason, the fittings on each end have VERY small openings, maybe 1/8 inch. Not all hoses are created equal....
03-16-2021, 10:19 AM
Natalie,
Since it has a 2-stage regulator, you have to open the valve on the tank slowly or else it will restrict the gas flow as a safety feature sensing it as a gas leak, and not allow sufficient flow to light your stove, etc.
03-16-2021, 03:20 PM
Originally Posted by mszabo
Not in my case. I bought a dual stage regulator with 5 foot hose from Amazon. When I went to mount it, I realized the hose was much longer than I needed so I bought a 2 foot hose. I was surprised that the 2 footer was very restricted despite the 3/8 fittings. So I reluctantly reinstalled the 5 foot hose and returned the shorter one.
03-16-2021, 03:27 PM
Be safe >> Go see a professional propane guy or gal.
03-20-2021, 10:11 AM
had same problem low pressure was regulator put new one on and it came to life ,flame better on stove etc . I thought tank but was reg. Change it is cheaper than change tank etc
03-20-2021, 11:37 AM
New Mexico
Charles
Yes! I have 2010 Casita and exactly 10 years later (2020) the regulator went kaput while out on a long drycamping trip. Best to take care of it when you are close to an RV Parts store or carry an extra one with you. Just my 2 cents.
03-20-2021, 02:28 PM
Trailer: Former Scamp 13, Former Airstream 16
Connecticut
Snuffy 2-
I don't think there is a stated service life for regulators, but 2 1/2 years is pretty short. Guessing CAMCO has them made to their specs overseas, but not 100% sure about that.
I would recommend replacing it with a quality brand like Marshall if you plan to hang onto your trailer for more than a year or two.
Many regulators are serviceable by a professional. I would say it's probably not worth servicing the CAMCO.
