Puddle on the door side - Fiberglass RV
Old 06-12-2021, 01:46 PM   #1
Ohio
Iím out camping in the southwest Ohio heat and humidity. All is well except my AC is making a mess on the ground by my door. I played with the level of the camper and now am making a mess by the tire. Are there techniques to channel the AC condensation to the rear? I guess they put the AC drain on the door side because all the appliances are on the other side. It would seem nice to send the water flow that way. I have some ideas but just wondering whatís been done already.
Tony D is offline   Reply With Quote
Old 06-12-2021, 03:37 PM   #2
Ive had the water run off about every direction, so changing level should help. But another trick is to attach a string at the very point that the water comes off the roof and starts down the wall. Then slope the string away from the camper (maybe six feet). The capillary action will cause the water to flow along the string. Its not perfect and takes some trial and error but I have done it with some success. Long term you could try a longer RV gutter over the door.
Old 06-12-2021, 07:17 PM   #3
Ohio
Thanks Gordon. Iíll try the string. Iím wondering if I can devise a ďgutterĒ to run along the belly band. Attach it when needed.
Rear Door VS Side door GregLucas General Chat 11 02-15-2020 11:04 AM
Beds Running Lengthwise Rather Than Side to Side? Cathy P. General Chat 20 05-21-2013 04:52 PM
side-to-side balance havingfunnow Towing, Hitching, Axles and Running Gear 10 01-04-2013 05:08 PM
Water Leak -Puddle under rear window cushion Dave Storey Problem Solving | Owners Helping Owners 14 05-06-2011 11:56 AM
2000 Watt Yamaha vs Honda side by side Larry Harmon General Chat 13 03-05-2009 09:00 AM
