questions about rivets. - Fiberglass RV
Old 05-05-2021, 11:38 AM   #1
Trailer: Trillium
Saskatchewan
I just have a couple question about rivets on these units. I have a Trillium 1300 that the drip cap needs replacing. I am wondering what you guys do with the old rivets that are drilled out, do you pull back the ensolite and pull the inside half of the rivet out or leave it in there? Same thing with the rivets for the roof vent... do you guys drill it out, then push the old rivet into the ensolite or pull the ensolite back and take it out? I don't want to do too much damage to it if I don't have to. Also do you fill the rivet with some kind of sealant?
Leif Sperling is offline   Reply With Quote
Old 05-05-2021, 12:06 PM   #2
John in Michigan's Avatar
Trailer: 1979 Boler 1700
I have fished out rivets if I can do it without damaging the ensolite. For example, if you could drill out all of the rivets in the roof vent, then remove the roof vent, then fish out the rivet remains along the edges of the ensolite, then re-seal and re-install the roof vent or a new roof vent.
If the ensolite would be damaged in the process of removing the rivet remains, I just leave the remains behind the ensolite.
Old 05-05-2021, 03:03 PM   #3
Trailer: Trillium
Saskatchewan
Thank you for your help! Have you ever replaced the door drip cap? If so did you have to leave the remains behind it?
Old 05-05-2021, 04:02 PM   #4
Yes, I have replaced the drip cap on a trailer, and no I did not disassemble the ensolite and trim to remove the remains. I left the remains inside the ensolite.
Old 05-05-2021, 04:10 PM   #5
It is very difficult to avoid damaging the ensolite and door edge molding when peeling it back. I have not had to replace the riveted-on drip cap on my Trillium 4500. If you are replacing the door frame molding (EDIT: the door frame seal/gasket), you could attempt to remove the rivet remains at that time. That might work.
Old 05-08-2021, 09:18 PM   #6
[QUOTE= Also do you fill the rivet with some kind of sealant?[/QUOTE]
Get marine rivets, they are self sealing. Any good marine repair place should have them or try on line.
Bing M. is offline   Reply With Quote
Old 05-15-2021, 11:51 AM   #7
Borden's Avatar
Name: Borden and Carole
Spaenaur.com sells closed end marine rivets, Stanley makes them.
Our postage stamp in heaven.
questions, questions, questions cathybr Problem Solving | Owners Helping Owners 4 06-22-2017 10:47 PM
Rivets: more questions... Uncle Cereal Problem Solving | Owners Helping Owners 13 07-07-2016 02:43 PM
Pre-painting questions - snaps and rivets Uncle Cereal Problem Solving | Owners Helping Owners 0 03-05-2016 03:50 PM
A few questions ... okay, more like a lot of questions! shelley w Problem Solving | Owners Helping Owners 6 07-04-2012 10:25 PM
Replacement windows, questions, questions. CliveAlive Modifications, Alterations and Updates 4 07-13-2006 07:32 AM
