I've been looking into the lizard skin spray insulation, is it primarily used for sound?... What other kinds of spray insulation can I use? Would I be able to use it the interior of an aluminum rv as well?
I bought it on-line at 72" Marine Hulliner "Ivory"
because it was white. Scamp sells theirs but it looked brown/tan in the pictures, but based on our last Scamp, their liner is thicker. I don't know if that makes much difference. It was easy to work with as you could stretch it a bit to conform to the curves, but I did have to cut out some darts in the compound corners. I would imagine that you could get some at a boat repair shop...that way you could look at it in person instead of a picture. I'm installing LED ribbon lights within our cupboards that have magnetic switches that I bought from another FGRV member, Larry at beetlefreak.com
Next I'm going to install a Propex HS 2000 heater like "McDenny" did, except in a different location.
Dave & Paula
Hey Dave & Paula,
I'm about to replace my rat fur in the scamp. How is this material holding up for you?
Holding up very well, with no problems what so ever, after using DAP High Temp headliner spray-on adhesive, as the 3M did not hold up to the Arizona heat.
Dave & Paula
