Rat Fur Replacement 1996 16' Scamp - Fiberglass RV
Old 08-02-2020, 02:04 PM   #1
Hi all,
We're in the process of renewing the rat fur (and reflectix foil) in our 1996 16' Scamp. I'm hoping someone can share their experience with a project like this. We've removed almost all of the rat fur and foil underneath, but didn't remove the pieces that are behind the cupboards or the closet. My plan is to cut the new foil and rat fur to pieces and place it as tight as possible to all cupboards, trying to avoid any slits and gaps. Maybe even 'seal' it with extra stripes of rat fur (similar to what scamp does).
I'd remove the windows, however, to not take the risk of any leaks. But as for all the remaining furniture, I wouldn't remove them to replace foil and rat fur, but would rather 'work around' them.
I'm not bothered at all by all the work ahead of me I Just want to make sure there's nothing terribly wrong with that approach. Do I risk the stability of my Scamp? Do I risk mold, moisture, or anything else?
Here's a picture so my question doesn't get lost:
https://www.instagram.com/p/CCSLdDAp..._web_copy_link
Trilooo89 is offline   Reply With Quote
Old 08-03-2020, 09:33 AM   #2
BatDude's Avatar
Trailer: Escape
Rat fur?
Start trapping squirrels and get a glue gun? Maybe 50K squirrel tails will cover it?
OK sorry been cooped up too long w/o being on the road as much as we prefer.
I am sure multitudes of others will have reasonable suggestions.
Bat Dude
Conservation biologist specializing in bats. Now stepping aside from paid $ bat work and just Escaping, painting and mentoring grad students
BatDude is offline   Reply With Quote
Old 08-04-2020, 01:14 AM   #3
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
I have found that I had to use a high temperature headliner glue from DAP, because the 3M let loose in the hot Arizona sun. I also found that it was much easier if you have two people working the rat fur using paint rollers instead of your hands, as hands tended to stretch the fabric causing wrinckles.
Dave & Paula
Old 08-04-2020, 12:42 PM   #4
this is what you need. Probably cant get it in California due to VOC content hope You have people out of state. water base contact adhesives suck don't use 3/m supper 77 at minimum you need super 90 for the heat rating but I have never used it on large hot areas.
https://www.dap.com/products-project...ndau-top-trim/
Formica backsplash over Scamp rat fur? peterh Problem Solving | Owners Helping Owners 53 10-05-2017 09:38 PM
Inside material...replacement for rat fur? Christyn Midwestyn Modifications, Alterations and Updates 16 08-20-2015 06:49 PM
interior rat fur replacement Pat B Ohio Problem Solving | Owners Helping Owners 0 10-14-2008 03:14 PM
Scamp "Rat Fur" William L. Care and Feeding of Molded Fiberglass Trailers 9 10-13-2008 01:59 AM
Scamp rat fur: help andre robillard Problem Solving | Owners Helping Owners 6 04-29-2007 04:33 PM
