Re-hanging Boler door - Fiberglass RV
Old 09-18-2013, 06:44 PM   #1
BarterBoler's Avatar
Trailer: Boler
nova scotia
Hi all. I am gearing up to rehang my door after all my renovations. I ruined the original hinges so I will be using the ones from Scamp. I have been sear chin for answers/tip on two things;
1. Any experience putting back on the metal reinforcement bar that attaches to the inner hinge side of the door frame? From what I can tell I would line it back up, clamp the shell to the bar and attach, drilling in from the outside. Any suggestions on how to line up the holes that are in the bar when screwing in from the outside?
2. Tips on hanging the door in general; tricks on aligning the door and hinges to get the best fit. (we know the doors are notoriously bad fits)
Thanks for any tips you may have learned through doing these things already.
BarterBoler is offline   Reply With Quote
Old 09-20-2013, 12:31 PM   #2
Ian G.'s Avatar
There is Good and Bad in using Scamp hinges (which I have now on my Boler)
Bad
1) None of the holes align with the original mounting holes, both the spacing and the locations are different
2) Each leaf of the hinge are not parallel, in that they do not lay flat from the Boler body to the door. Shims or spacers need to be installed under the door side of the hinge for the door to lay flush and close tight
Good
1) the hinge offset is better when opening and allows the door to fully open back before it hits the belly band
2) the hinges are stronger with the additional bolt on the body side hold the hinge better with less slipping
Because you have to drill new holes I made steel plates for the inside that are drilled and align with the mounting holes. Large fender washers could also be used but would not distribute the load quite as well.
Ian G. is offline   Reply With Quote
Old 09-20-2013, 07:16 PM   #3
Beverly Jones's Avatar
Trailer: 1975 Boler
I will need to do the same soon, just purchased a 1975 Boler...has the chronic sagging door. Seems they separate at the union where outside wall seperates from inside door bench, floor and frame....so finding not just a hinge fix.
Are you finding the same?
Beverly Jones is offline   Reply With Quote
Old 05-21-2016, 08:51 AM   #4
Trailer: 1936 Kaycraft Kampster
Idaho
wall separating from inside door bench
if i understand your post, this is precisely what has occured in our boler. would love to see some imput on this quandry. were you able to work a fix to yours, Beverly?
hdpendent is offline   Reply With Quote
Old 05-23-2016, 09:11 AM   #5
Roy in TO's Avatar
Common problem. Search this site for "body bulge".
Old 05-23-2016, 09:17 AM   #6
Idaho
door sag
yes, thank you Roy. Have been reading alot since that post. Plan to learn how to do some fiberglassing next.
boler
Door hanging on Trillium x2uol Problem Solving | Owners Helping Owners 3 09-10-2012 08:29 PM
Boler door hinge repair kit and fridge access door John Jesse Problem Solving | Owners Helping Owners 5 05-27-2011 12:32 PM
Hanging curtains in the Boler kevin61 Modifications, Alterations and Updates 2 07-16-2009 11:34 AM
Left hanging... yvonne Care and Feeding of Molded Fiberglass Trailers 3 06-12-2008 06:26 PM
scamp door - anybody try hanging it on the left? lenny247 Problem Solving | Owners Helping Owners 15 06-13-2006 07:32 AM
