Refrig Burner Gas Fitting - Fiberglass RV
Old 02-06-2020, 07:04 PM   #1
Trailer: 2002 Casita 17 ft Spirit Deluxe / 2012 Lincoln MKT
Anyone know what the size/description of the fitting the propane line mates to at the burner assembly? Dometic RM-2453 Refrigerator.
I'm installing a propane filter at the location where the propane inlet line joins the burner assembly. I get small black particles clogging the #43 jet.
Have tried to find the source of the particles for a year with no success. Have the filter with 1/4 NPT but having a problem find the proper fittings to transition to the propane line and burner assembly.
Thanks for any help!
Elvin Lowe is offline   Reply With Quote
Old 02-07-2020, 02:27 PM   #2
Take the trailer to someone that deals with propane and let them find the problem. Don't mess with something as dangerous as propane if you don't know what to do. Fix the problem. Don't put a band aid on it. Your line or tank has a problem so find it. It could be the rubber line is corroding inside and it would start leaking eventually. I had one on a trailer I'd bought a few months before and had never used yet that burst while it was in the shop getting the fridge replaced. If we'd been using it we could've had a fire or worse.
Old 02-07-2020, 02:57 PM   #3
Trailer: 2013Escape 21
Iowa
Fittings
Sorry I don’t have that model but can tell you that some Dometic fittings are metric. When I’m working on a fitting that has a flared line going through it, I like a wrench that encircles the fitting and has one section out of 6 open for the line. You won’t slip off and bang the line. With that many points of contact. We always used them on steel brake lines and steel fuel lines “back in the day”. I would definitely advise against using an adjustable angle wrench ( crescent or like brand) on this kind of job. YMMV
Iowa Dave
Iowa Dave is offline   Reply With Quote
Old 02-07-2020, 08:02 PM   #4
Fittings
Thanks for the info and suggestions. Bought propane at various places. Changed tanks when this started but particles could have already been in system. Located all the fittings and have filter. Communicated with someone with similar problem and he did exactly what I plan.
Thanks again for the info and advice!
Old 02-22-2020, 12:47 PM   #5
Trailer: 1975 Scamp, 13-foot
Redding, California
Iowa Dave
They're called "tubing" wrenches. I have two sets: imperial and metric, and wouldn't be without them.
Harold
Doctor Harold is offline   Reply With Quote
Old 02-22-2020, 06:29 PM   #6
Already removed all and installed a filter. Fitting is a 3/16 SAE 45 degree. All is good after 300 miles on the road. Fitting is not metric on mine.
two gas burner removal Scamp 13/2014 Snowberry Modifications, Alterations and Updates 2 04-22-2016 07:44 PM
Replacing a 2 burner stove with the full 3 burner/over combo - 2005 Bigfoot dkerr Modifications, Alterations and Updates 3 06-18-2014 07:09 PM
FOUND: two-burner gas stove for Boler François P. Classified Archives 6 11-10-2009 12:43 PM
2 way Refrig Jim Paskett Problem Solving | Owners Helping Owners 13 01-29-2006 04:58 PM
Need Refrig Info Legacy Posts Care and Feeding of Molded Fiberglass Trailers 9 03-22-2003 11:50 AM
